[petsc-dev] Issues with DMComplexGetTransitiveClosure in Fortran
    Matthew Knepley
    knepley at gmail.com
    Tue Aug 28 21:16:12 CDT 2012
On Tue, Aug 28, 2012 at 5:01 PM, Chris Eldred <chris.eldred at gmail.com>wrote:
> On Tue, Aug 28, 2012 at 3:49 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Tue, Aug 28, 2012 at 4:39 PM, Chris Eldred <chris.eldred at gmail.com>
> > wrote:
> >> DMComplexGetTransitiveClosure does not appear to have the calling
> >> sequence (DM dm, PetscInt p, PetscBool useCone, PetscInt *numPoints,
> >> PetscInt *points[]) indicated in the documentation- instead it has DM
> >> dm, PetscInt p, PetscBool useCone, PetscInt *points[]. In addition, it
> >> does not appear to be returning the full closure- instead it just
> >> gives cone + the point.
> > 1) I will turn this code into a running example
> Awesome! I have been using the Doublet mesh to test DMComplex routines
> and my own functions, so that is great.
Okay, there was a bug in the array handling. The test is
  src/dm/impls/complex/examples/tests/ex2f90.F
     Matt
> > 2) I will fix the documentation. The interface change for Fortran comes
> > because the size
> >     is embedded in the array pointer. If you think I should still return
> the
> > size in Fortran,
> >     let me know.
> I can get the size from the array pointer so just returning that works.
> > 3) I will also check to make sure the documentation is clear that this
> thing
> > returns each
> >     point AND its orientation.
> > Will write again when I have your thing running. It could be an error
> with
> > the Fortran array
> > processing I put in.
> >   Thanks,
> >      Matt
> >> Sample code is below:
> >> program main
> >> implicit none
> >> ! #echo '#include <finclude/petscsys.h>\n'
> >> #echo '#include <finclude/petsc.h90>'
> >> #echo '#include <finclude/petscdmcomplex.h>\n'
> >> #echo '#include <finclude/petscdmcomplex.h90>'
> >> ! #echo '#include <finclude/petscdm.h>\n'
> >> ! #echo '#include <finclude/petscdm.h90>\n'
> >> DM dm
> >> PetscInt, target, dimension(3) :: EC
> >> PetscInt, target, dimension(2) :: VE
> >> PetscInt, pointer :: pEC(:), pVE(:)
> >> PetscInt, pointer :: nClosure(:)
> >> PetscInt, pointer :: pClosure(:), pCone(:), pCone2(:)
> >> PetscErrorCode ierr
> >> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexCreate(PETSC_COMM_WORLD, dm, ierr)
> >> CHKERRQ(ierr)
> >> !Make Doublet Mesh from Fig 2 of Flexible Representation of
> >> Computational Meshes (except indexing is from 0 instead of 1)
> >> call DMComplexSetChart(dm, 0, 11, ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexSetConeSize(dm, 9, 3,ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexSetConeSize(dm, 10, 3,ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexSetConeSize(dm, 4, 2,ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexSetConeSize(dm, 5, 2,ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexSetConeSize(dm, 6, 2,ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexSetConeSize(dm, 7, 2,ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexSetConeSize(dm, 8, 2,ierr)
> >> CHKERRQ(ierr)
> >> call DMSetUp(dm, ierr)
> >> CHKERRQ(ierr)
> >> EC(1) = 4
> >> EC(2) = 5
> >> EC(3) = 6
> >> pEC => EC
> >> call DMComplexSetCone(dm, 9 , pEC, ierr)
> >> CHKERRQ(ierr)
> >> EC(1) = 6
> >> EC(2) = 7
> >> EC(3) = 8
> >> pEC => EC
> >> call DMComplexSetCone(dm, 10 , pEC, ierr)
> >> CHKERRQ(ierr)
> >> VE(1) = 0
> >> VE(2) = 1
> >> pVE => VE
> >> call DMComplexSetCone(dm, 4 , pVE, ierr)
> >> CHKERRQ(ierr)
> >> VE(1) = 0
> >> VE(2) = 2
> >> pVE => VE
> >> call DMComplexSetCone(dm, 5 , pVE, ierr)
> >> CHKERRQ(ierr)
> >> VE(1) = 1
> >> VE(2) = 2
> >> pVE => VE
> >> call DMComplexSetCone(dm, 6 , pVE, ierr)
> >> CHKERRQ(ierr)
> >> VE(1) = 2
> >> VE(2) = 3
> >> pVE => VE
> >> call DMComplexSetCone(dm, 7 , pVE, ierr)
> >> CHKERRQ(ierr)
> >> VE(1) = 1
> >> VE(2) = 3
> >> pVE => VE
> >> call DMComplexSetCone(dm, 8 , pVE, ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexSymmetrize(dm,ierr)
> >> CHKERRQ(ierr)
> >> call DMComplexStratify(dm,ierr)
> >> CHKERRQ(ierr)
> >> !Test Stuff
> >> call DMComplexGetTransitiveClosure(dm,10,PETSC_TRUE,nClosure,ierr)
> >> !pClosure,ierr)
> >> CHKERRQ(ierr)
> >> write(*,*) nClosure
> >> write(*,*) pClosure
> >> call DMDestroy(dm,ierr)
> >> CHKERRQ(ierr)
> >> call PetscFinalize(ierr)
> >> CHKERRQ(ierr)
> >> end
> >> The output is:
> >>           10           0           6           0           7
> >> 0           8
> >> and then there is an error in DMDestroy
> >> [0]PETSC ERROR: --------------------- Error Message
> >> [0]PETSC ERROR: Object is in wrong state!
> >> [0]PETSC ERROR: Work array still checked out!
> >> [0]PETSC ERROR:
> >> [0]PETSC ERROR: Petsc Development HG revision:
> >> b6fe82991deee4a0d3f9a20654bc7750a6b1fe0f  HG Date: Mon Aug 27 13:17:10
> >> 2012 -0500
> >> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> >> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> >> [0]PETSC ERROR: See docs/index.html for manual pages.
> >> [0]PETSC ERROR:
> >> [0]PETSC ERROR: ./test on a arch-linu named Puget-101334 by user Tue
> >> Aug 28 15:31:06 2012
> >> [0]PETSC ERROR: Libraries linked from
> >> /home/user/Desktop/LIBRARIES/petsc-dev/arch-linux2-cxx-debug/lib
> >> [0]PETSC ERROR: Configure run at Mon Aug 27 12:55:14 2012
> >> [0]PETSC ERROR: Configure options --download-boost --download-chaco
> >> --download-ctetgen --download-f-blas-lapack --download-fiat
> >> --download-generator --download-metis --download-ml --download-mpich
> >> --download-parmetis --download-scientificpython --download-triangle
> >> --with-clanguage=cxx --with-dynamic-loading --with-shared-libraries
> >> --with-sieve PETSC_ARCH=arch-linux2-cxx-debug
> >> [0]PETSC ERROR:
> >> [0]PETSC ERROR: DMDestroy() line 234 in
> >> /home/user/Desktop/LIBRARIES/petsc-dev/src/dm/interface/dm.c
> >> application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
> >> [unset]: aborting job:
> >> Ideas?
> >> Chris Eldred
> >> DOE Computational Science Graduate Fellow
> >> Graduate Student, Atmospheric Science, Colorado State University
> >> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
> Chris Eldred
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120828/c6cfab5b/attachment.html>
