[petsc-dev] Issues with DMComplexGetTransitiveClosure in Fortran
Matthew Knepley
knepley at gmail.com
Tue Aug 28 16:49:07 CDT 2012
On Tue, Aug 28, 2012 at 4:39 PM, Chris Eldred <chris.eldred at gmail.com>wrote:
> DMComplexGetTransitiveClosure does not appear to have the calling
> sequence (DM dm, PetscInt p, PetscBool useCone, PetscInt *numPoints,
> PetscInt *points[]) indicated in the documentation- instead it has DM
> dm, PetscInt p, PetscBool useCone, PetscInt *points[]. In addition, it
> does not appear to be returning the full closure- instead it just
> gives cone + the point.
1) I will turn this code into a running example
2) I will fix the documentation. The interface change for Fortran comes
because the size
is embedded in the array pointer. If you think I should still return
the size in Fortran,
let me know.
3) I will also check to make sure the documentation is clear that this
thing returns each
point AND its orientation.
Will write again when I have your thing running. It could be an error with
the Fortran array
processing I put in.
Matt
> Sample code is below:
> program main
> implicit none
> ! #echo '#include <finclude/petscsys.h>\n'
> #echo '#include <finclude/petsc.h90>'
> #echo '#include <finclude/petscdmcomplex.h>\n'
> #echo '#include <finclude/petscdmcomplex.h90>'
> ! #echo '#include <finclude/petscdm.h>\n'
> ! #echo '#include <finclude/petscdm.h90>\n'
> DM dm
> PetscInt, target, dimension(3) :: EC
> PetscInt, target, dimension(2) :: VE
> PetscInt, pointer :: pEC(:), pVE(:)
> PetscInt, pointer :: nClosure(:)
> PetscInt, pointer :: pClosure(:), pCone(:), pCone2(:)
> PetscErrorCode ierr
> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> CHKERRQ(ierr)
> call DMComplexCreate(PETSC_COMM_WORLD, dm, ierr)
> CHKERRQ(ierr)
> !Make Doublet Mesh from Fig 2 of Flexible Representation of
> Computational Meshes (except indexing is from 0 instead of 1)
> call DMComplexSetChart(dm, 0, 11, ierr)
> CHKERRQ(ierr)
> call DMComplexSetConeSize(dm, 9, 3,ierr)
> CHKERRQ(ierr)
> call DMComplexSetConeSize(dm, 10, 3,ierr)
> CHKERRQ(ierr)
> call DMComplexSetConeSize(dm, 4, 2,ierr)
> CHKERRQ(ierr)
> call DMComplexSetConeSize(dm, 5, 2,ierr)
> CHKERRQ(ierr)
> call DMComplexSetConeSize(dm, 6, 2,ierr)
> CHKERRQ(ierr)
> call DMComplexSetConeSize(dm, 7, 2,ierr)
> CHKERRQ(ierr)
> call DMComplexSetConeSize(dm, 8, 2,ierr)
> CHKERRQ(ierr)
> call DMSetUp(dm, ierr)
> CHKERRQ(ierr)
> EC(1) = 4
> EC(2) = 5
> EC(3) = 6
> pEC => EC
> call DMComplexSetCone(dm, 9 , pEC, ierr)
> CHKERRQ(ierr)
> EC(1) = 6
> EC(2) = 7
> EC(3) = 8
> pEC => EC
> call DMComplexSetCone(dm, 10 , pEC, ierr)
> CHKERRQ(ierr)
> VE(1) = 0
> VE(2) = 1
> pVE => VE
> call DMComplexSetCone(dm, 4 , pVE, ierr)
> CHKERRQ(ierr)
> VE(1) = 0
> VE(2) = 2
> pVE => VE
> call DMComplexSetCone(dm, 5 , pVE, ierr)
> CHKERRQ(ierr)
> VE(1) = 1
> VE(2) = 2
> pVE => VE
> call DMComplexSetCone(dm, 6 , pVE, ierr)
> CHKERRQ(ierr)
> VE(1) = 2
> VE(2) = 3
> pVE => VE
> call DMComplexSetCone(dm, 7 , pVE, ierr)
> CHKERRQ(ierr)
> VE(1) = 1
> VE(2) = 3
> pVE => VE
> call DMComplexSetCone(dm, 8 , pVE, ierr)
> CHKERRQ(ierr)
> call DMComplexSymmetrize(dm,ierr)
> CHKERRQ(ierr)
> call DMComplexStratify(dm,ierr)
> CHKERRQ(ierr)
> !Test Stuff
> call DMComplexGetTransitiveClosure(dm,10,PETSC_TRUE,nClosure,ierr)
> !pClosure,ierr)
> CHKERRQ(ierr)
> write(*,*) nClosure
> write(*,*) pClosure
> call DMDestroy(dm,ierr)
> CHKERRQ(ierr)
> call PetscFinalize(ierr)
> CHKERRQ(ierr)
> end
> The output is:
> 10 0 6 0 7
> 0 8
> and then there is an error in DMDestroy
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state!
> [0]PETSC ERROR: Work array still checked out!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Development HG revision:
> b6fe82991deee4a0d3f9a20654bc7750a6b1fe0f HG Date: Mon Aug 27 13:17:10
> 2012 -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./test on a arch-linu named Puget-101334 by user Tue
> Aug 28 15:31:06 2012
> [0]PETSC ERROR: Libraries linked from
> /home/user/Desktop/LIBRARIES/petsc-dev/arch-linux2-cxx-debug/lib
> [0]PETSC ERROR: Configure run at Mon Aug 27 12:55:14 2012
> [0]PETSC ERROR: Configure options --download-boost --download-chaco
> --download-ctetgen --download-f-blas-lapack --download-fiat
> --download-generator --download-metis --download-ml --download-mpich
> --download-parmetis --download-scientificpython --download-triangle
> --with-clanguage=cxx --with-dynamic-loading --with-shared-libraries
> --with-sieve PETSC_ARCH=arch-linux2-cxx-debug
> [0]PETSC ERROR:
> [0]PETSC ERROR: DMDestroy() line 234 in
> /home/user/Desktop/LIBRARIES/petsc-dev/src/dm/interface/dm.c
> application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
> [unset]: aborting job:
> Ideas?
> Chris Eldred
> DOE Computational Science Graduate Fellow
> Graduate Student, Atmospheric Science, Colorado State University
> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120828/f05da915/attachment.html>
