[petsc-dev] Issues with DMComplexGetTransitiveClosure in Fortran
Chris Eldred chris.eldred at gmail.com
Tue Aug 28 16:39:15 CDT 2012
DMComplexGetTransitiveClosure does not appear to have the calling
sequence (DM dm, PetscInt p, PetscBool useCone, PetscInt *numPoints,
PetscInt *points[]) indicated in the documentation- instead it has DM
dm, PetscInt p, PetscBool useCone, PetscInt *points[]. In addition, it
does not appear to be returning the full closure- instead it just
gives cone + the point.
Sample code is below:
program main
implicit none
! #echo '#include <finclude/petscsys.h>\n'
#echo '#include <finclude/petsc.h90>'
#echo '#include <finclude/petscdmcomplex.h>\n'
#echo '#include <finclude/petscdmcomplex.h90>'
! #echo '#include <finclude/petscdm.h>\n'
! #echo '#include <finclude/petscdm.h90>\n'
DM dm
PetscInt, target, dimension(3) :: EC
PetscInt, target, dimension(2) :: VE
PetscInt, pointer :: pEC(:), pVE(:)
PetscInt, pointer :: nClosure(:)
PetscInt, pointer :: pClosure(:), pCone(:), pCone2(:)
PetscErrorCode ierr
call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
CHKERRQ(ierr)
call DMComplexCreate(PETSC_COMM_WORLD, dm, ierr)
CHKERRQ(ierr)
!Make Doublet Mesh from Fig 2 of Flexible Representation of
Computational Meshes (except indexing is from 0 instead of 1)
call DMComplexSetChart(dm, 0, 11, ierr)
CHKERRQ(ierr)
call DMComplexSetConeSize(dm, 9, 3,ierr)
CHKERRQ(ierr)
call DMComplexSetConeSize(dm, 10, 3,ierr)
CHKERRQ(ierr)
call DMComplexSetConeSize(dm, 4, 2,ierr)
CHKERRQ(ierr)
call DMComplexSetConeSize(dm, 5, 2,ierr)
CHKERRQ(ierr)
call DMComplexSetConeSize(dm, 6, 2,ierr)
CHKERRQ(ierr)
call DMComplexSetConeSize(dm, 7, 2,ierr)
CHKERRQ(ierr)
call DMComplexSetConeSize(dm, 8, 2,ierr)
CHKERRQ(ierr)
call DMSetUp(dm, ierr)
CHKERRQ(ierr)
EC(1) = 4
EC(2) = 5
EC(3) = 6
pEC => EC
call DMComplexSetCone(dm, 9 , pEC, ierr)
CHKERRQ(ierr)
EC(1) = 6
EC(2) = 7
EC(3) = 8
pEC => EC
call DMComplexSetCone(dm, 10 , pEC, ierr)
CHKERRQ(ierr)
VE(1) = 0
VE(2) = 1
pVE => VE
call DMComplexSetCone(dm, 4 , pVE, ierr)
CHKERRQ(ierr)
VE(1) = 0
VE(2) = 2
pVE => VE
call DMComplexSetCone(dm, 5 , pVE, ierr)
CHKERRQ(ierr)
VE(1) = 1
VE(2) = 2
pVE => VE
call DMComplexSetCone(dm, 6 , pVE, ierr)
CHKERRQ(ierr)
VE(1) = 2
VE(2) = 3
pVE => VE
call DMComplexSetCone(dm, 7 , pVE, ierr)
CHKERRQ(ierr)
VE(1) = 1
VE(2) = 3
pVE => VE
call DMComplexSetCone(dm, 8 , pVE, ierr)
CHKERRQ(ierr)
call DMComplexSymmetrize(dm,ierr)
CHKERRQ(ierr)
call DMComplexStratify(dm,ierr)
CHKERRQ(ierr)
!Test Stuff
call DMComplexGetTransitiveClosure(dm,10,PETSC_TRUE,nClosure,ierr)
!pClosure,ierr)
CHKERRQ(ierr)
write(*,*) nClosure
write(*,*) pClosure
call DMDestroy(dm,ierr)
CHKERRQ(ierr)
call PetscFinalize(ierr)
CHKERRQ(ierr)
end
The output is:
          10           0           6           0           7
0           8
and then there is an error in DMDestroy
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state!
[0]PETSC ERROR: Work array still checked out!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
b6fe82991deee4a0d3f9a20654bc7750a6b1fe0f  HG Date: Mon Aug 27 13:17:10
2012 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./test on a arch-linu named Puget-101334 by user Tue
Aug 28 15:31:06 2012
[0]PETSC ERROR: Libraries linked from
/home/user/Desktop/LIBRARIES/petsc-dev/arch-linux2-cxx-debug/lib
[0]PETSC ERROR: Configure run at Mon Aug 27 12:55:14 2012
[0]PETSC ERROR: Configure options --download-boost --download-chaco
--download-ctetgen --download-f-blas-lapack --download-fiat
--download-generator --download-metis --download-ml --download-mpich
--download-parmetis --download-scientificpython --download-triangle
--with-clanguage=cxx --with-dynamic-loading --with-shared-libraries
--with-sieve PETSC_ARCH=arch-linux2-cxx-debug
[0]PETSC ERROR:
[0]PETSC ERROR: DMDestroy() line 234 in
/home/user/Desktop/LIBRARIES/petsc-dev/src/dm/interface/dm.c
application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
[unset]: aborting job:
Ideas?
Chris Eldred
DOE Computational Science Graduate Fellow
Graduate Student, Atmospheric Science, Colorado State University
B.S. Applied Computational Physics, Carnegie Mellon University, 2009
