[petsc-dev] [PATCH 3 of 3] cmake: replace invalid characters	with underscores
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Aug 27 19:22:41 CDT 2012
On Mon, Aug 27, 2012 at 6:32 PM, Sean Farley <sean at mcs.anl.gov> wrote:
> On Mon, Aug 27, 2012 at 10:51 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Does this really work?
> "Works for me."
> > Barry's problem-configure from a while back left
> > stuff like this
> > PETSC_-FRAMEWORK_LIB:FILEPATH=PETSC_-FRAMEWORK_LIB-NOTFOUND
> > This came from passing --with-opengl-lib="-framework glut -framework
> opengl"
> > to configure.
> One thing that changed is that Barry added '-framework opengl ...' here:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/86c9a3787fc2
> and maybe this did something, too:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/40f9515d8b01
> > I don't see the logic above that is going to produce
> > PETSC_GLUT_LIB and PETSC_OPENGL_LIB.
> You are right. Though those symbols don't exist currently in
> petsc-dev. Based on your feedback, I was able to find
> PETSC_FRAMEWORK_OPENGL_LIB. This probably works for mac because the
> PETSC_HAVE_OPENGL test succeeded and -framework was passed blindly
> somewhere in the link line.
> What about also getting rid of '_FRAMEWORK' by doing this instead:
> diff --git a/config/PETSc/Configure.py b/config/PETSc/Configure.py
> --- a/config/PETSc/Configure.py
> +++ b/config/PETSc/Configure.py
> @@ -436,11 +436,11 @@
>        extendby(self.libraries.rt)
>        extendby(self.compilers.flibs)
>        extendby(self.compilers.cxxlibs)
>        extendby(self.compilers.LIBS.split())
>        for libname in nublast(lib_libs):
> -        libvar = 'PETSC_' + libname.upper() + '_LIB'
> +        libvar = 'PETSC_' + libname.upper().replace('-','').replace('
> ','_').replace('_FRAMEWORK','') + '_LIB'
>          addpath = ''
>          for lpath in nublast(lib_paths):
>            addpath += '"' + str(lpath) + '" '
>          fd.write('find_library (' + libvar + ' ' + libname + ' HINTS
> ' + addpath + ')\n')
>          libvars.append(libvar)
We still need to find a way to ensure that "-framework opengl" is passed to
the linker. This just fixes the variable name, but doesn't parse the option
and forward it to the linker (which CMake is very obstinate about).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120827/5e0f768f/attachment.html>
