[petsc-dev] [PATCH 3 of 3] cmake: replace invalid characters with underscores
Sean Farley sean at mcs.anl.gov
Mon Aug 27 18:32:57 CDT 2012
On Mon, Aug 27, 2012 at 10:51 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Does this really work?
"Works for me."
> Barry's problem-configure from a while back left
> stuff like this
> PETSC_-FRAMEWORK_LIB:FILEPATH=PETSC_-FRAMEWORK_LIB-NOTFOUND
> This came from passing --with-opengl-lib="-framework glut -framework opengl"
> to configure.
One thing that changed is that Barry added '-framework opengl ...' here:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/86c9a3787fc2
and maybe this did something, too:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/40f9515d8b01
> I don't see the logic above that is going to produce
> PETSC_GLUT_LIB and PETSC_OPENGL_LIB.
You are right. Though those symbols don't exist currently in
petsc-dev. Based on your feedback, I was able to find
PETSC_FRAMEWORK_OPENGL_LIB. This probably works for mac because the
PETSC_HAVE_OPENGL test succeeded and -framework was passed blindly
somewhere in the link line.
What about also getting rid of '_FRAMEWORK' by doing this instead:
diff --git a/config/PETSc/Configure.py b/config/PETSc/Configure.py
--- a/config/PETSc/Configure.py
+++ b/config/PETSc/Configure.py
@@ -436,11 +436,11 @@
       extendby(self.libraries.rt)
       extendby(self.compilers.flibs)
       extendby(self.compilers.cxxlibs)
       extendby(self.compilers.LIBS.split())
       for libname in nublast(lib_libs):
-        libvar = 'PETSC_' + libname.upper() + '_LIB'
+        libvar = 'PETSC_' + libname.upper().replace('-','').replace('
','_').replace('_FRAMEWORK','') + '_LIB'
         addpath = ''
         for lpath in nublast(lib_paths):
           addpath += '"' + str(lpath) + '" '
         fd.write('find_library (' + libvar + ' ' + libname + ' HINTS
' + addpath + ')\n')
         libvars.append(libvar)
