[petsc-dev] Moar namespacing
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Aug 27 15:54:19 CDT 2012
On Mon, Aug 27, 2012 at 3:48 PM, Blaise Bourdin <bourdin at lsu.edu> wrote:
> actually, what is the meaning of is in fortran? I can't find it as a
> keyword in any of my 2003 ref, so it must be a 2008 or later thing.
See Fortran 2003 section 8.1.5 SELECT TYPE construct. There are phrase TYPE
IS, CLASS IS, and CLASS DEFAULT.
It appears that a lone IS doesn't parse specially, but if you use this
construct, the PETSc's IS definition causes trouble.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120827/9327a0ad/attachment.html>
