[petsc-dev] [petsc-maint #129715] __float128 complex
    Jose E. Roman
    jroman at dsic.upv.es
    Mon Aug 27 11:25:01 CDT 2012
El 23/08/2012, a las 18:27, Satish Balay escribió:
> On Thu, 23 Aug 2012, Jose E. Roman wrote:
>> Anyway, it would be a good opportunity to upgrade to Lapack 3.4 (the
>> toclapack.sh script should work for this version as well).
> Ok. Will do this. Hower I see a bunch of embeded code in toclapack.sh
> - corresponding to different lapack versions. Would this be a problem?
> Satish
> asterix:/home/balay/spetsc/bin/maint>grep -i version toclapack.sh |grep LAPACK
> /*  -- LAPACK auxiliary routine (version 3.3.0) -- */
> /*  -- LAPACK auxiliary routine (version 3.0) --
> /*  -- LAPACK routine (version 3.2.2) -- */
> #/*  -- LAPACK auxiliary routine (version 3.1) -- */
Satish, I have pushed a fix for toclapack.sh so that it can be used with Lapack 3.4.1 (thanks to Eloy).
The embeded routines are auxiliary routines that have not been updated in recent versions of Lapack. So it is safe to keep them as they are now.
Thanks.
Jose
