[petsc-dev] [petsc-maint #129715] __float128 complex
    Jose E. Roman
    jroman at dsic.upv.es
    Thu Aug 23 11:33:08 CDT 2012
El 23/08/2012, a las 18:27, Satish Balay escribió:
> On Thu, 23 Aug 2012, Jose E. Roman wrote:
>> Anyway, it would be a good opportunity to upgrade to Lapack 3.4 (the
>> toclapack.sh script should work for this version as well).
> Ok. Will do this. Hower I see a bunch of embeded code in toclapack.sh
> - corresponding to different lapack versions. Would this be a problem?
> Satish
> asterix:/home/balay/spetsc/bin/maint>grep -i version toclapack.sh |grep LAPACK
> /*  -- LAPACK auxiliary routine (version 3.3.0) -- */
> /*  -- LAPACK auxiliary routine (version 3.0) --
> /*  -- LAPACK routine (version 3.2.2) -- */
> #/*  -- LAPACK auxiliary routine (version 3.1) -- */
There should be no problem. Anyway, we will check this and modify toclapack.sh if necessary. We will also test the w* subrotines more. I will come back to you tomorrow.
Jose
