[petsc-dev] Ghost values in sieve
    Matthew Knepley
    knepley at gmail.com
    Thu Aug 23 13:54:45 CDT 2012
On Thu, Aug 23, 2012 at 1:42 PM, Chris Eldred <chris.eldred at gmail.com>wrote:
> I need the adjacency relations discussed in my other post- the only
> one that is not part of closure(p) U star(p) is: U
> cone(support(edge)). Given an edge p, I need all of the edges that
> cover the same cell as edge p.
Okay, then for parallelism, I think you need nothing more than the SF we get
from Jacobian preallocation.
     Matt
> On Thu, Aug 23, 2012 at 12:17 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Thu, Aug 23, 2012 at 12:26 PM, Chris Eldred <chris.eldred at gmail.com>
> > wrote:
> >> Yes- I am implementing the TriSK scheme
> >> (www.mmm.ucar.edu/people/skamarock/Ringler_et_al_JCP_2009.pdf) on
> >> arbitrary Voronoi meshes. In order to do wind/flux reconstruction at
> >> the cell edges, it needs to know about the edges of adjacent cells-
> >> which are outside of closure(p) U star(p).
> > Great! Stuff that cannot be done with that structured crap. However, from
> > quickly looking at
> > the paper, there is nothing beyond the neighbors, so we can reuse the
> code
> > from
> > Jacobian preallocation. If you could tell me exactly what adjacency you
> > need, we might be
> > able to do it even more simply.
> >    Matt
> >> On Thu, Aug 23, 2012 at 11:16 AM, Jed Brown <jedbrown at mcs.anl.gov>
> wrote:
> >> > On Thu, Aug 23, 2012 at 12:12 PM, Chris Eldred <
> >> > wrote:
> >> >> Thanks- that helps a lot. If I need stencils that are larger than
> >> >> closure(p) U star(p) (for a higher-order finite difference method,
> for
> >> >> example), I assume that I need to create my own PetscSF's that
> >> >> describe which points need to be ghosted?
> >> > Is this still a fully unstructured method? The Sieve formalism doesn't
> >> > give
> >> > you a very efficient way to do this for structured or semi-structured
> >> > grids.
> >> > Even so, if wider stencils are to be supported, I think it should be
> >> > implemented within the library. Doing it outside with the current
> >> > infrastructure is going to be quite a rabbit hole.
> >> >> Is there some documentation or example code that explains the theory
> >> >> behind star forests?
> >> > Docs for the basic operations:
> >> > http://59A2.org/files/StarForest.pdf
> >> Chris Eldred
> >> DOE Computational Science Graduate Fellow
> >> Graduate Student, Atmospheric Science, Colorado State University
> >> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
> Chris Eldred
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120823/90c2ac7e/attachment.html>
