[petsc-dev] FieldSplit fixes in 3.3
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Aug 23 09:53:12 CDT 2012
On Aug 22, 2012, at 8:46 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Wed, Aug 22, 2012 at 8:35 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Should MatCreateSchurComplement() be done properly the  PETSc way:   that is normal usage is
>      MatSetType(mat,MATSCHURCOMPLEMENT);
>      /* now if you want you can muck with the inner KSP */
>            MatSchurComplementGetKSP(mat,&ksp);
>      MatSchurComplementSetSubMats(mat,……)       note: could merge with MatSchurComplementUpdate()
>        and MatCreateSchurComplement() is just a convenience routine that calls the pieces in order and is NOT used directly by field split
> Yes
   The dreaded KSPIncrementTabLevel() is no more. All tests pass, not that that means must.
