[petsc-dev] FieldSplit fixes in 3.3
Barry Smith
bsmith at mcs.anl.gov
Wed Aug 22 20:38:55 CDT 2012
On Aug 22, 2012, at 8:46 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Wed, Aug 22, 2012 at 8:35 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Should MatCreateSchurComplement() be done properly the PETSc way: that is normal usage is
> MatSetType(mat,MATSCHURCOMPLEMENT);
> /* now if you want you can muck with the inner KSP */
> MatSchurComplementGetKSP(mat,&ksp);
> MatSchurComplementSetSubMats(mat,……) note: could merge with MatSchurComplementUpdate()
> and MatCreateSchurComplement() is just a convenience routine that calls the pieces in order and is NOT used directly by field split
> Yes
Working on this now. Will push after tested.
Barry
