[petsc-dev] FieldSplit fixes in 3.3
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Wed Aug 22 01:16:14 CDT 2012
On Tue, Aug 21, 2012 at 8:46 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Aug 21, 2012 at 2:53 AM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
>> On Mon, Aug 20, 2012 at 8:36 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Mon, Aug 20, 2012 at 4:02 AM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
>>>> On Sun, Aug 19, 2012 at 1:17 PM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>> On Sun, Aug 19, 2012 at 12:48 PM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
>>>>>> The main reason for this being a patch in 3.3 is that recursive
>>>>>> FieldSplit is broken there (which is why I couldn't enable it in
>>>>>> libMesh/Moose correctly).
>>>>> The current interface doesn't explicitly support all the ways to get
>>>>> information into the split, but several people have worked around the
>>>>> limitations to get the necessary information in there. Having you and Matt
>>>>> changing things to rely on mutually incompatible side-effects does not
>>>>> help.
>>>> I don't think the present fix is about the API or working through side
>>>> effects (nullspace stuff excluded and partially backed out here:
>>>> http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/1723d4624521)
>>> What do you call this external DM futzing?
>> It's no different than holding onto the ISs set in
>> PCFieldSplitSetDefaults() or directly via PCFieldSplitSetIS() until they
>> can be used in PCSetUp_FieldSplit(). I don't see how this can be avoided
>> here or in the future, unless we do something to fundamentally change the
>> set up process.
> As I said earlier, I think we should use KSPSetDM/KSPGetDM. A DMShell
> should not be a problem because it just won't implement some routines. At
> least in 3.3, there are probably cases where ksp->dm is misused, but we
> should fix those places instead of cluttering fieldsplit.
> In your revised patch, why this extra conditional?
> +          ilink->dm = dms[i];
> +          if(ilink->dm) {
> +            ierr =
> PetscObjectReference((PetscObject)ilink->dm);CHKERRQ(ierr);
> Is it the case that DMCreateFieldDecomposition() can return an array
> containing some DMs and some NULL? If so, I think we should change it so
> that a DM is always returned (even if it's just a DMShell).
Okay, I'll fix it in petsc-dev.
>>>>  The current interface assumes that the A00 solver and the Schur inner
>>>> solver are to be set up identically
>>> If they are being set up identically, they should literally be the same
>>> object. This is often the biggest setup cost in the whole problem (e.g.
>>> AMG).
>> I agree, but that's available only in petsc-dev, not in petsc-3.3.  The
>> duplicate setup has been occurring all along, now it is actually consistent
>> with the DM being forwarded to the inner solver.
> With Schur, we don't even use the link->ksp. Look at
> PCApply_FieldSplit_Schur(). Why are we setting this thing up? Where in
> PCSetUp_FieldSplit() is it really being set up?
Only jac->head->ksp is being set from options in case of Schur.  All
inlink->ksp is set from options otherwise.
> I also don't like part of
> http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/3c0d43fb5911
>  +     Set from options only the A00 split.  The other split's solver
> won't be used with Schur.
> +     Should it be destroyed?  Should KSPCreate() be moved here from
> PCFieldSplitSetIS() and invoked
> +     only when necessary?
> +    ierr = KSPSetFromOptions(jac->head->ksp);CHKERRQ(ierr);
>      /* need to handle case when one is resetting up the preconditioner */
>      if (jac->schur) {
> This call is being done every time through PCSetUp_FieldSplit(), which it
> shouldn't be. It's also being called on a KSP that is not being used for
> anything (e.g. look at the "if (jac->type == PC_COMPOSITE_SCHUR) {" part of
jac->head->ksp is used for the A00 solve with SCHUR_FULL.  We could further
classify the types of set up that are needed based on the type of Schur
used.
> Now, checking to see what has happened in this flurry of patches and
> partial reversions:
> $ hg diff -r dbc8d9af8577 src/ksp/pc/impls/    # revision is before all of
> your changes
> I would like to get rid of these superfluous hunks that we just talked
> about
>        ierr  =
> KSPCreate(((PetscObject)pc)->comm,&jac->kspschur);CHKERRQ(ierr);
>        ierr  =
> PetscLogObjectParent((PetscObject)pc,(PetscObject)jac->kspschur);CHKERRQ(ierr);
>        ierr  =
> PetscObjectIncrementTabLevel((PetscObject)jac->kspschur,(PetscObject)pc,1);CHKERRQ(ierr);
> +        PC pcschur;
> +        ierr           = KSPGetPC(jac->kspschur, &pcschur); CHKERRQ(ierr);
> +        ierr           =
> PetscObjectIncrementTabLevel((PetscObject)pcschur,(PetscObject)pc,1);CHKERRQ(ierr);
> @@ -1108,6 +1152,11 @@
>    ilink->next    = PETSC_NULL;
>     ierr           =
> KSPCreate(((PetscObject)pc)->comm,&ilink->ksp);CHKERRQ(ierr);
>    ierr           =
> PetscObjectIncrementTabLevel((PetscObject)ilink->ksp,(PetscObject)pc,1);CHKERRQ(ierr);
> +    PC ilinkpc;
> +    ierr           = KSPGetPC(ilink->ksp, &ilinkpc); CHKERRQ(ierr);
> +    ierr           =
> PetscObjectIncrementTabLevel((PetscObject)ilinkpc,(PetscObject)pc,1);CHKERRQ(ierr);
How are these superfluous? Without them -ksp_monitor formatting is wrong.
The inner PC has to be indented, not just the KSP.
> I thought we agreed in this thread that we were (for now) going with
> Matt's bastardized model of attaching the Schur null space to A11. Doesn't
> that mean that this hunk should also be reverted (and have a comment
> explaining this indirect effect)?
> @@ -568,31 +586,54 @@
>        /* Use mat[0] (diagonal block of the real matrix) preconditioned by
> pmat[0] */
>        ierr  =
> MatCreateSchurComplement(jac->mat[0],jac->pmat[0],jac->B,jac->C,jac->mat[1],&jac->schur);CHKERRQ(ierr);
>         ierr  = MatGetNullSpace(jac->pmat[1], &sp);CHKERRQ(ierr);
> -      if (sp) {ierr  = MatSetNullSpace(jac->schur, sp);CHKERRQ(ierr);}
> -      /* set tabbing and options prefix of KSP inside the MatSchur */
> +       Do we really want to attach the A11-block's nullspace to S? Note
> that this may generate
> +       "false positives", when the A11's nullspace isn't S's: Stokes or A
> = [1, 1; 1, 0].
> +       Using a false nullspace may prevent KSP(S) from converging, since
>  it might force an inconsistent rhs.
> +      /* if (sp) {ierr  = MatSetNullSpace(jac->schur, sp);CHKERRQ(ierr);}
> +      /* set tabbing, options prefix and DM of KSP inside the
> MatSchurComplement */
My mistake, I fixed this here, along with the formatting:
http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/652d3b1b7d99
> Also, I like to use hg backout to revert changesets because then we don't
> end up with trivial formatting changes like this in the diff (new
> violations of Barry's formatting guidelines, no less)
> @@ -604,15 +645,17 @@
>      ierr =
> PetscObjectQuery((PetscObject)pc->pmat,lscname,(PetscObject*)&LSC_L);CHKERRQ(ierr);
>      if (!LSC_L) {ierr =
> PetscObjectQuery((PetscObject)pc->mat,lscname,(PetscObject*)&LSC_L);CHKERRQ(ierr);}
>      if (LSC_L) {ierr =
> PetscObjectCompose((PetscObject)jac->schur,"LSC_Lp",(PetscObject)LSC_L);CHKERRQ(ierr);}
> -  } else {
> -    /* set up the individual PCs */
> +  else {
> +    /* set up the individual splits' PCs */
> -      if (!jac->suboptionsset) {ierr =
> KSPSetFromOptions(ilink->ksp);CHKERRQ(ierr);}
> +      if (!jac->suboptionsset) {
> +        ierr = KSPSetFromOptions(ilink->ksp);CHKERRQ(ierr);
Fixed.
> -      ierr = PetscSNPrintf(schurprefix,sizeof
> schurprefix,"%sfieldsplit_%s_",((PetscObject)pc)->prefix?((PetscObject)pc)->prefix:"",ilink->splitname);CHKERRQ(ierr);
> -      ierr  =
> KSPSetOptionsPrefix(jac->kspschur,schurprefix);CHKERRQ(ierr);
>        /* really want setfromoptions called in
> PCSetFromOptions_FieldSplit(), but it is not ready yet */
>        /* need to call this every time, since the jac->kspschur is freshly
> created, otherwise its options never get set */
> -      ierr = KSPSetFromOptions(jac->kspschur);CHKERRQ(ierr);
> +      ierr = PetscSNPrintf(schurprefix,sizeof
> +      ierr = KSPSetOptionsPrefix(jac->kspschur,schurprefix);CHKERRQ(ierr);
> +      ierr = KSPSetFromOptions(jac->kspschur); CHKERRQ(ierr);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120822/e6865d88/attachment.html>
