[petsc-dev] FieldSplit fixes in 3.3
Tue Aug 21 21:03:25 CDT 2012
On Tue, Aug 21, 2012 at 8:59 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Aug 21, 2012 at 8:51 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> I thought we agreed in this thread that we were (for now) going with
>>> Matt's bastardized model of attaching the Schur null space to A11. Doesn't
>>> that mean that this hunk should also be reverted (and have a comment
>>> explaining this indirect effect)?
>> For future reference, this was my bastardized model in 3.3, but in
>> petsc-dev I either
>>   a) attach them to IS on input, which works beautifully
>> or
>>   b) Tell the DM about them
> In either case, what happens when you switch back and forth between Schur
> and, e.g. multiplicative? Does that cause there to be a different IS or a
> different DM?
You are right, it has the same conceptual flaw.
> I fear that by including the physics in the DM, we may be obligated to
> have a DMGetSchurComplement() (or, in the more general nonlinear language,
> DMEliminate()). Note that some mixed discretizations have sparse Schur
> complements and it could even make sense to implement a nonlinear smoother
> in the reduced space.
I really do not want to do that, at least not now since we have not even
shaken out all the FS implications or have a library of common split PCs,
nor
have we gotten nonlinear FS working. After that, we can do DMEliminate(),
if DM still exists.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120821/d966569e/attachment.html>
