[petsc-dev] YAML patch take 3
Fri Aug 17 14:12:36 CDT 2012
I'll test this. I'm impressed by how much code you have removed and I'm
happy to put it in petsc-dev, but we're building up a lot of changes to
petsc-3.3. Should we call the next patch release 3.3.1 instead of 3.3p?
It's a significant enough change that people should be able to test for it
with the PETSC_VERSION_ macros.
This line can certainly be removed.
+#define PETSC_MAX_YAML_LEN 128000
On Fri, Aug 17, 2012 at 1:52 PM, Blaise Bourdin <bourdin at lsu.edu> wrote:
> Hi,
> Here is a revised version of my YAML patch that eliminates the limit on
> the yaml file length. Is there any rational objection to pushing it to
> petsc-3.3 and petsc-dev?
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
> http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120817/ae46d7c5/attachment.html>
