[petsc-dev] broken TS example related to Jacobian and coloring	etc.
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Aug 15 07:41:04 CDT 2012
On Aug 15, 2012, at 1:03 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Aug 14, 2012 at 5:03 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> But you've just told me that ONLY ts is allowed to use the SNESSetJacobian() context slot (coloring and presumably users) aren't allowed to.
> Not at all. I mean that coloring as produced internally by SNES should not ascribe special meaning to that field being NULL or not. You could perhaps have -snes_fd_color create an empty coloring object and put it into the callback slowt. We should perhaps support destructors for function/Jacobian contexts.
    I think it uses null in order to delay computing the matrix coloring etc from the time of SNESSetJacobian() to a later time.   I guess what could happen is it creates a n "empty" fdcoloring beast and passes that into SNESSetJacobian() and then fills it up later when it has the information it needs.
    Barry
