[petsc-dev] broken TS example related to Jacobian and coloring	etc.
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Aug 14 17:16:48 CDT 2012
On Tue, Aug 14, 2012 at 3:56 PM, Peter Brune <prbrune at gmail.com> wrote:
> Correct; the sheer amount of code using this convention makes it
> exceedingly painful to fix.  It would be much easier to alter our
> internals.  I'm *this* close to fugueing on TS especially and removing all
> PetscObjects from ctx arguments internal to PETSc.  We can pass the TS
> around by PetscObjectCompose using the coarsen/restrict hooks.
We could also punt with
void *PETSC_NULL_FORCE = &knownlocation;
I like the dogfooding of having TS pass itself as the context to SNES, but
could be convinced to change my mind.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120814/5843cfbc/attachment.html>
