[petsc-dev] broken TS example related to Jacobian and coloring	etc.
    Peter Brune
    prbrune at gmail.com
    Tue Aug 14 16:28:19 CDT 2012
This is a problem I've been harping on but should harp on more; It is
IMPOSSIBLE to reset the context on a lot of things to null after it's been
set.  What's happening is that the context is being set as the TS object in
the previous setting of the SNES jacobian in TSSetRHSJacobian.  Then, this
call is expecting it to have a MatFDColoring.  I could just make
SNESDefaultComputeJacobianColor ignore its context argument, but I left it
in there so that a user could pass their own coloring in.
It's my opinion that sticking PetscObjects in the context field like the
SNES wrappers for TS function and jacobian evaluations do is a bad habit.
However, just composing it with, say, the DM won't give us the flexibility
we need if, for instance, we want multilevel methods to work on this.
- Peter
On Tue, Aug 14, 2012 at 4:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Things are still mighty fragile ----
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Invalid argument!
> > [0]PETSC ERROR: Wrong type of object: Parameter # 6!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Development HG revision:
> bd03fdcd3cf87c5b29ea28a5f4737ae936d9df04  HG Date: Sat Aug 11 20:22:42 2012
> -0500
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [1]PETSC ERROR: --------------------- Error Message
> > [1]PETSC ERROR: Invalid argument!
> > [1]PETSC ERROR: Wrong type of object: Parameter # 6!
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: Petsc Development HG revision:
> -0500
> > [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [1]PETSC ERROR: See docs/index.html for manual pages.
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: ./ex13 on a arch-gnu named Barrys-MacBook-Pro.local by
> barrysmith Mon Aug 13 21:36:58 2012
> > [2]PETSC ERROR: --------------------- Error Message
> > [2]PETSC ERROR: Invalid argument!
> > [2]PETSC ERROR: Wrong type of object: Parameter # 6!
> > [2]PETSC ERROR:
> > [2]PETSC ERROR: Petsc Development HG revision:
> -0500
> > [2]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [2]PETSC ERROR: See docs/index.html for manual pages.
> > [2]PETSC ERROR:
> > [2]PETSC ERROR: ./ex13 on a arch-gnu named Barrys-MacBook-Pro.local by
> > [2]PETSC ERROR: Libraries linked from
> /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> > [2]PETSC ERROR: Configure run at Sat Aug 11 20:25:02 2012
> > [2]PETSC ERROR: Configure options --download-blacs --download-fftw
> --download-hypre --download-libyaml --download-metis --download-ml
> --download-mpich --download-mumps --download-parmetis --download-ptscotch
> --download-scalapack --download-superlu --download-superlu_dist
> --download-triangle --download-yaml
> --with-ams-dir=/Users/barrysmith/Src/ams-dev --with-java --with-openmp
> --with-server --with-shared-libraries PETSC_ARCH=arch-gnu
> > [2]PETSC ERROR: [0]PETSC ERROR:
> > [0]PETSC ERROR: ./ex13 on a arch-gnu named Barrys-MacBook-Pro.local by
> > [0]PETSC ERROR: Libraries linked from
> > [0]PETSC ERROR: Configure run at Sat Aug 11 20:25:02 2012
> > [0]PETSC ERROR: Configure options --download-blacs --download-fftw
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: SNESDefaultComputeJacobianColor() line 50 in
> /Users/barrysmith/Src/petsc-dev/src/snes/interface/snesj2.c
> > [0]PETSC ERROR: SNESComputeJacobian() line 2079 in
> /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> > [0]PETSC ERROR: SNESSolve_LS() line 198 in
> /Users/barrysmith/Src/petsc-dev/src/snes/impls/ls/ls.c
> > [0]PETSC ERROR: SNESSolve() line 3570 in
> > [1]PETSC ERROR: Libraries linked from
> > [1]PETSC ERROR: Configure run at Sat Aug 11 20:25:02 2012
> > [1]PETSC ERROR: Configure options --download-blacs --download-fftw
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: SNESDefaultComputeJacobianColor() line 50 in
> > [1]PETSC ERROR: SNESComputeJacobian() line 2079 in
> > [1]PETSC ERROR: SNESSolve_LS() line 198 in
> > [1]PETSC ERROR: SNESSolve() line 3570 in
> > [1]PETSC ERROR: TSStep_Theta() line 116 in
> /Users/barrysmith/Src/petsc-dev/src/ts/impls/implicit/theta/theta.c
> > [1]PETSC ERROR:
> > [2]PETSC ERROR: SNESDefaultComputeJacobianColor() line 50 in
> > [2]PETSC ERROR: SNESComputeJacobian() line 2079 in
> > [2]PETSC ERROR: SNESSolve_LS() line 198 in
> > [2]PETSC ERROR: SNESSolve() line 3570 in
> > [2]PETSC ERROR: TSStep_Theta() line 116 in
> > [2]PETSC ERROR: TSStep() line 1977 in
> /Users/barrysmith/Src/petsc-dev/src/ts/interface/ts.c
> > [2]PETSC ERROR: TSSolve() line 2100 in
> > [0]PETSC ERROR: TSStep_Theta() line 116 in
> > [0]PETSC ERROR: TSStep() line 1977 in
> > [0]PETSC ERROR: TSSolve() line 2100 in
> > [0]PETSC ERROR: main() line 108 in src/ts/examples/tutorials/ex13.c
> > [1]PETSC ERROR: TSSolve() line 2100 in
> > [1]PETSC ERROR: main() line 108 in src/ts/examples/tutorials/ex13.c
> > [2]PETSC ERROR: main() line 108 in src/ts/examples/tutorials/ex13.c
> > application called MPI_Abort(MPI_COMM_WORLD, 62) - process 0
> > [cli_0]: aborting job:
> > application called MPI_Abort(MPI_COMM_WORLD, 62) - process 1
> > [cli_1]: aborting job:
> > application called MPI_Abort(MPI_COMM_WORLD, 62) - process 2
> > [cli_2]: aborting job:
> /Users/barrysmith/Src/petsc-dev/src/ts/examples/tutorials
> Possible problem with ex13_3, diffs above
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120814/1eacf6df/attachment.html>
