[petsc-dev] broken TS example related to Jacobian and coloring etc.
Tue Aug 14 16:12:19 CDT 2012
  Things are still mighty fragile ----
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Invalid argument!
> [0]PETSC ERROR: Wrong type of object: Parameter # 6!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Development HG revision: bd03fdcd3cf87c5b29ea28a5f4737ae936d9df04  HG Date: Sat Aug 11 20:22:42 2012 -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR: --------------------- Error Message ------------------------------------
> [1]PETSC ERROR: Invalid argument!
> [1]PETSC ERROR: Wrong type of object: Parameter # 6!
> [1]PETSC ERROR: ------------------------------------------------------------------------
> [1]PETSC ERROR: Petsc Development HG revision: bd03fdcd3cf87c5b29ea28a5f4737ae936d9df04  HG Date: Sat Aug 11 20:22:42 2012 -0500
> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [1]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR: ./ex13 on a arch-gnu named Barrys-MacBook-Pro.local by barrysmith Mon Aug 13 21:36:58 2012
> [2]PETSC ERROR: --------------------- Error Message ------------------------------------
> [2]PETSC ERROR: Invalid argument!
> [2]PETSC ERROR: Wrong type of object: Parameter # 6!
> [2]PETSC ERROR: ------------------------------------------------------------------------
> [2]PETSC ERROR: Petsc Development HG revision: bd03fdcd3cf87c5b29ea28a5f4737ae936d9df04  HG Date: Sat Aug 11 20:22:42 2012 -0500
> [2]PETSC ERROR: See docs/changes/index.html for recent updates.
> [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [2]PETSC ERROR: See docs/index.html for manual pages.
> [2]PETSC ERROR: ./ex13 on a arch-gnu named Barrys-MacBook-Pro.local by barrysmith Mon Aug 13 21:36:58 2012
> [2]PETSC ERROR: Libraries linked from /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> [2]PETSC ERROR: Configure run at Sat Aug 11 20:25:02 2012
> [2]PETSC ERROR: Configure options --download-blacs --download-fftw --download-hypre --download-libyaml --download-metis --download-ml --download-mpich --download-mumps --download-parmetis --download-ptscotch --download-scalapack --download-superlu --download-superlu_dist --download-triangle --download-yaml --with-ams-dir=/Users/barrysmith/Src/ams-dev --with-java --with-openmp --with-server --with-shared-libraries PETSC_ARCH=arch-gnu
> [2]PETSC ERROR: [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: ./ex13 on a arch-gnu named Barrys-MacBook-Pro.local by barrysmith Mon Aug 13 21:36:58 2012
> [0]PETSC ERROR: Libraries linked from /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> [0]PETSC ERROR: Configure run at Sat Aug 11 20:25:02 2012
> [0]PETSC ERROR: Configure options --download-blacs --download-fftw --download-hypre --download-libyaml --download-metis --download-ml --download-mpich --download-mumps --download-parmetis --download-ptscotch --download-scalapack --download-superlu --download-superlu_dist --download-triangle --download-yaml --with-ams-dir=/Users/barrysmith/Src/ams-dev --with-java --with-openmp --with-server --with-shared-libraries PETSC_ARCH=arch-gnu
> [0]PETSC ERROR: SNESDefaultComputeJacobianColor() line 50 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snesj2.c
> [0]PETSC ERROR: SNESComputeJacobian() line 2079 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> [0]PETSC ERROR: SNESSolve_LS() line 198 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: SNESSolve() line 3570 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> [1]PETSC ERROR: Libraries linked from /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> [1]PETSC ERROR: Configure run at Sat Aug 11 20:25:02 2012
> [1]PETSC ERROR: Configure options --download-blacs --download-fftw --download-hypre --download-libyaml --download-metis --download-ml --download-mpich --download-mumps --download-parmetis --download-ptscotch --download-scalapack --download-superlu --download-superlu_dist --download-triangle --download-yaml --with-ams-dir=/Users/barrysmith/Src/ams-dev --with-java --with-openmp --with-server --with-shared-libraries PETSC_ARCH=arch-gnu
> [1]PETSC ERROR: SNESDefaultComputeJacobianColor() line 50 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snesj2.c
> [1]PETSC ERROR: SNESComputeJacobian() line 2079 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> [1]PETSC ERROR: SNESSolve_LS() line 198 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/ls/ls.c
> [1]PETSC ERROR: SNESSolve() line 3570 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> [1]PETSC ERROR: TSStep_Theta() line 116 in /Users/barrysmith/Src/petsc-dev/src/ts/impls/implicit/theta/theta.c
> [2]PETSC ERROR: SNESDefaultComputeJacobianColor() line 50 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snesj2.c
> [2]PETSC ERROR: SNESComputeJacobian() line 2079 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> [2]PETSC ERROR: SNESSolve_LS() line 198 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/ls/ls.c
> [2]PETSC ERROR: SNESSolve() line 3570 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> [2]PETSC ERROR: TSStep_Theta() line 116 in /Users/barrysmith/Src/petsc-dev/src/ts/impls/implicit/theta/theta.c
> [2]PETSC ERROR: TSStep() line 1977 in /Users/barrysmith/Src/petsc-dev/src/ts/interface/ts.c
> [2]PETSC ERROR: TSSolve() line 2100 in /Users/barrysmith/Src/petsc-dev/src/ts/interface/ts.c
> [0]PETSC ERROR: TSStep_Theta() line 116 in /Users/barrysmith/Src/petsc-dev/src/ts/impls/implicit/theta/theta.c
> [0]PETSC ERROR: TSStep() line 1977 in /Users/barrysmith/Src/petsc-dev/src/ts/interface/ts.c
> [0]PETSC ERROR: TSSolve() line 2100 in /Users/barrysmith/Src/petsc-dev/src/ts/interface/ts.c
> [0]PETSC ERROR: main() line 108 in src/ts/examples/tutorials/ex13.c
> [1]PETSC ERROR: TSSolve() line 2100 in /Users/barrysmith/Src/petsc-dev/src/ts/interface/ts.c
> [1]PETSC ERROR: main() line 108 in src/ts/examples/tutorials/ex13.c
> [2]PETSC ERROR: main() line 108 in src/ts/examples/tutorials/ex13.c
> application called MPI_Abort(MPI_COMM_WORLD, 62) - process 0
> [cli_0]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, 62) - process 1
> [cli_1]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, 62) - process 2
> [cli_2]: aborting job:
/Users/barrysmith/Src/petsc-dev/src/ts/examples/tutorials
Possible problem with ex13_3, diffs above
