[petsc-dev] annoying Nan in tests
Peter Brune
prbrune at gmail.com
Mon Aug 13 21:24:24 CDT 2012
Something broke; I think I see what it is from your logs. I'll fix it.
- Peter
On Mon, Aug 13, 2012 at 9:17 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> What's up with this stuff? Are they bugs? Bad algorithms? What? It is
> hard to make a major change to PETSc (and use alltests to check that you
> haven't broken anything) when this crap comes up constantly.
> Is there a plan to deal with this or are we just screwed forever?
> Barry
> 1 SNES Function norm 59.1937
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Floating point exception!
> > [0]PETSC ERROR: Vec entry at local location 83 is not-a-number or
> infinite at end of function: Parameter number 3!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Development HG revision:
> bd03fdcd3cf87c5b29ea28a5f4737ae936d9df04 HG Date: Sat Aug 11 20:22:42 2012
> -0500
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: ./ex5 on a arch-gnu named Barrys-MacBook-Pro.local by
> barrysmith Mon Aug 13 21:12:18 2012
> > [0]PETSC ERROR: Libraries linked from
> /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> > [0]PETSC ERROR: Configure run at Sat Aug 11 20:25:02 2012
> > [0]PETSC ERROR: Configure options --download-blacs --download-fftw
> --download-hypre --download-libyaml --download-metis --download-ml
> --download-mpich --download-mumps --download-parmetis --download-ptscotch
> --download-scalapack --download-superlu --download-superlu_dist
> --download-triangle --download-yaml
> --with-ams-dir=/Users/barrysmith/Src/ams-dev --with-java --with-openmp
> --with-server --with-shared-libraries PETSC_ARCH=arch-gnu
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: SNESComputeFunction() line 1927 in
> /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> > [0]PETSC ERROR: SNESLineSearchApply_Basic() line 41 in
> /Users/barrysmith/Src/petsc-dev/src/snes/linesearch/impls/basic/linesearchbasic.c
> > [0]PETSC ERROR: SNESLineSearchApply() line 506 in
> /Users/barrysmith/Src/petsc-dev/src/snes/linesearch/interface/linesearch.c
> > [0]PETSC ERROR: SNESSolve_NRichardson() line 181 in
> /Users/barrysmith/Src/petsc-dev/src/snes/impls/richardson/snesrichardson.c
> > [0]PETSC ERROR: SNESSolve() line 3570 in
> > [0]PETSC ERROR: SNESSolve_NGMRES() line 259 in
> /Users/barrysmith/Src/petsc-dev/src/snes/impls/ngmres/snesngmres.c
> > [0]PETSC ERROR: main() line 152 in src/snes/examples/tutorials/ex5.c
> > application called MPI_Abort(MPI_COMM_WORLD, 72) - process 0
> > [cli_0]: aborting job:
> /Users/barrysmith/Src/petsc-dev/src/snes/examples/tutorials
> Possible problem with with ex5_5_ngmres_richardson, diffs above
> 2,21c2,44
> < 1 SNES Function norm 0.18208
> < 2 SNES Function norm 0.0272102
> < 3 SNES Function norm 0.00491305
> < 4 SNES Function norm 0.000996383
> < 5 SNES Function norm 0.000243372
> < 6 SNES Function norm 6.53869e-05
> < 7 SNES Function norm 1.84573e-05
> < 8 SNES Function norm 5.30014e-06
> < 9 SNES Function norm 1.5228e-06
> < 10 SNES Function norm 4.34313e-07
> < 11 SNES Function norm 1.22592e-07
> < 12 SNES Function norm 3.42365e-08
> < 13 SNES Function norm 9.46937e-09
> < 14 SNES Function norm 2.59769e-09
> < 15 SNES Function norm 7.078e-10
> < 16 SNES Function norm 1.918e-10
> < 17 SNES Function norm 5.173e-11
> < 18 SNES Function norm 1.390e-11
> < 19 SNES Function norm < 1.e-11
> < 20 SNES Function norm < 1.e-11
> > [0]PETSC ERROR: Vec entry at local location 14 is not-a-number or
> > [0]PETSC ERROR:
> -0500
> > [0]PETSC ERROR:
> barrysmith Mon Aug 13 21:12:19 2012
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: SNESFASUpSmooth_Private() line 447 in
> /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
> > [0]PETSC ERROR: SNESFASCycle_Multiplicative() line 695 in
> > [0]PETSC ERROR: SNESSolve_FAS() line 774 in
> > [0]PETSC ERROR: SNESFASCoarseCorrection() line 567 in
> > [0]PETSC ERROR: SNESFASCycle_Multiplicative() line 694 in
> Possible problem with with ex5_5_fas, diffs above
> 2,11c2,46
> < 1 SNES Function norm 0.156469
> < 2 SNES Function norm 0.0115623
> < 3 SNES Function norm 0.00145395
> < 4 SNES Function norm 0.000151214
> < 5 SNES Function norm 1.97033e-05
> < 6 SNES Function norm 2.60149e-06
> < 7 SNES Function norm 3.26556e-07
> < 8 SNES Function norm 4.31521e-08
> < 9 SNES Function norm 5.41224e-09
> < 10 SNES Function norm 1.18135e-09
> > [0]PETSC ERROR:
> -0500
> > [0]PETSC ERROR:
> barrysmith Mon Aug 13 21:12:20 2012
> > [0]PETSC ERROR:
> Possible problem with with ex5_5_ngmres_fas, diffs above
> 2,51c2,46
> < 1 SNES Function norm 0.648993
> < 2 SNES Function norm 0.518893
> < 3 SNES Function norm 0.439196
> < 4 SNES Function norm 0.386902
> < 5 SNES Function norm 0.350239
> < 6 SNES Function norm 0.322173
> < 7 SNES Function norm 0.298913
> < 8 SNES Function norm 0.279868
> < 9 SNES Function norm 0.26322
> < 10 SNES Function norm 0.249106
> < 11 SNES Function norm 0.236341
> < 12 SNES Function norm 0.225242
> < 13 SNES Function norm 0.214976
> < 14 SNES Function norm 0.205853
> < 15 SNES Function norm 0.168755
> < 16 SNES Function norm 0.150005
> < 17 SNES Function norm 0.146453
> < 18 SNES Function norm 0.122221
> < 19 SNES Function norm 0.109397
> < 20 SNES Function norm 0.107737
> < 21 SNES Function norm 0.106311
> < 22 SNES Function norm 0.0907226
> < 23 SNES Function norm 0.0813505
> < 24 SNES Function norm 0.0796973
> < 25 SNES Function norm 0.0782834
> < 26 SNES Function norm 0.0770559
> < 27 SNES Function norm 0.0758003
> < 28 SNES Function norm 0.0746744
> < 29 SNES Function norm 0.0740446
> < 30 SNES Function norm 0.061927
> < 31 SNES Function norm 0.0549197
> < 32 SNES Function norm 0.054583
> < 33 SNES Function norm 0.0519673
> < 34 SNES Function norm 0.0498744
> < 35 SNES Function norm 0.0491159
> < 36 SNES Function norm 0.0482318
> < 37 SNES Function norm 0.047538
> < 38 SNES Function norm 0.0468002
> < 39 SNES Function norm 0.0461691
> < 40 SNES Function norm 0.0459809
> < 41 SNES Function norm 0.0420109
> < 42 SNES Function norm 0.0389469
> < 43 SNES Function norm 0.0383224
> < 44 SNES Function norm 0.0378171
> < 45 SNES Function norm 0.0375595
> < 46 SNES Function norm 0.0373267
> < 47 SNES Function norm 0.0370906
> < 48 SNES Function norm 0.0368703
> < 49 SNES Function norm 0.0366439
> < 50 SNES Function norm 0.0364308
> > 1 SNES Function norm 1.73715
> > 2 SNES Function norm 44.1655
> > 3 SNES Function norm 2.72388e+10
> > [0]PETSC ERROR: Vec entry at local location 8 is not-a-number or
> > [0]PETSC ERROR:
> -0500
> > [0]PETSC ERROR:
> barrysmith Mon Aug 13 21:12:21 2012
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: SNESFASDownSmooth_Private() line 420 in
> > [0]PETSC ERROR: SNESFASCycle_Additive() line 638 in
> > [0]PETSC ERROR: SNESSolve_FAS() line 776 in
> > [0]PETSC ERROR: SNESFASCycle_Additive() line 635 in
> Possible problem with with ex5_5_fas_additive, diffs above
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120813/e81f21d9/attachment.html>
