[petsc-dev] annoying Nan in tests
Mon Aug 13 21:17:13 CDT 2012
 What's up with this stuff? Are they bugs? Bad algorithms? What? It is hard to make a major change to PETSc (and use alltests to check that you haven't broken anything) when this crap comes up constantly.
   Is there a plan to deal with this or are we just screwed forever?
    Barry
   1 SNES Function norm 59.1937
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Floating point exception!
> [0]PETSC ERROR: Vec entry at local location 83 is not-a-number or infinite at end of function: Parameter number 3!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Development HG revision: bd03fdcd3cf87c5b29ea28a5f4737ae936d9df04  HG Date: Sat Aug 11 20:22:42 2012 -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./ex5 on a arch-gnu named Barrys-MacBook-Pro.local by barrysmith Mon Aug 13 21:12:18 2012
> [0]PETSC ERROR: Libraries linked from /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> [0]PETSC ERROR: Configure run at Sat Aug 11 20:25:02 2012
> [0]PETSC ERROR: Configure options --download-blacs --download-fftw --download-hypre --download-libyaml --download-metis --download-ml --download-mpich --download-mumps --download-parmetis --download-ptscotch --download-scalapack --download-superlu --download-superlu_dist --download-triangle --download-yaml --with-ams-dir=/Users/barrysmith/Src/ams-dev --with-java --with-openmp --with-server --with-shared-libraries PETSC_ARCH=arch-gnu
> [0]PETSC ERROR: SNESComputeFunction() line 1927 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> [0]PETSC ERROR: SNESLineSearchApply_Basic() line 41 in /Users/barrysmith/Src/petsc-dev/src/snes/linesearch/impls/basic/linesearchbasic.c
> [0]PETSC ERROR: SNESLineSearchApply() line 506 in /Users/barrysmith/Src/petsc-dev/src/snes/linesearch/interface/linesearch.c
> [0]PETSC ERROR: SNESSolve_NRichardson() line 181 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/richardson/snesrichardson.c
> [0]PETSC ERROR: SNESSolve() line 3570 in /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
> [0]PETSC ERROR: SNESSolve_NGMRES() line 259 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/ngmres/snesngmres.c
> [0]PETSC ERROR: main() line 152 in src/snes/examples/tutorials/ex5.c
> application called MPI_Abort(MPI_COMM_WORLD, 72) - process 0
> [cli_0]: aborting job:
/Users/barrysmith/Src/petsc-dev/src/snes/examples/tutorials
Possible problem with with ex5_5_ngmres_richardson, diffs above
2,21c2,44
<   1 SNES Function norm 0.18208
<   2 SNES Function norm 0.0272102
<   3 SNES Function norm 0.00491305
<   4 SNES Function norm 0.000996383
<   5 SNES Function norm 0.000243372
<   6 SNES Function norm 6.53869e-05
<   7 SNES Function norm 1.84573e-05
<   8 SNES Function norm 5.30014e-06
<   9 SNES Function norm 1.5228e-06
<  10 SNES Function norm 4.34313e-07
<  11 SNES Function norm 1.22592e-07
<  12 SNES Function norm 3.42365e-08
<  13 SNES Function norm 9.46937e-09
<  14 SNES Function norm 2.59769e-09
<  15 SNES Function norm 7.078e-10
<  16 SNES Function norm 1.918e-10
<  17 SNES Function norm 5.173e-11
<  18 SNES Function norm 1.390e-11
<  19 SNES Function norm < 1.e-11
<  20 SNES Function norm < 1.e-11
> [0]PETSC ERROR: Vec entry at local location 14 is not-a-number or infinite at end of function: Parameter number 3!
> [0]PETSC ERROR: ./ex5 on a arch-gnu named Barrys-MacBook-Pro.local by barrysmith Mon Aug 13 21:12:19 2012
> [0]PETSC ERROR: SNESFASUpSmooth_Private() line 447 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
> [0]PETSC ERROR: SNESFASCycle_Multiplicative() line 695 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
> [0]PETSC ERROR: SNESSolve_FAS() line 774 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
> [0]PETSC ERROR: SNESFASCoarseCorrection() line 567 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
> [0]PETSC ERROR: SNESFASCycle_Multiplicative() line 694 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
Possible problem with with ex5_5_fas, diffs above
2,11c2,46
<   1 SNES Function norm 0.156469
<   2 SNES Function norm 0.0115623
<   3 SNES Function norm 0.00145395
<   4 SNES Function norm 0.000151214
<   5 SNES Function norm 1.97033e-05
<   6 SNES Function norm 2.60149e-06
<   7 SNES Function norm 3.26556e-07
<   8 SNES Function norm 4.31521e-08
<   9 SNES Function norm 5.41224e-09
<  10 SNES Function norm 1.18135e-09
> [0]PETSC ERROR: ./ex5 on a arch-gnu named Barrys-MacBook-Pro.local by barrysmith Mon Aug 13 21:12:20 2012
Possible problem with with ex5_5_ngmres_fas, diffs above
2,51c2,46
<   1 SNES Function norm 0.648993
<   2 SNES Function norm 0.518893
<   3 SNES Function norm 0.439196
<   4 SNES Function norm 0.386902
<   5 SNES Function norm 0.350239
<   6 SNES Function norm 0.322173
<   7 SNES Function norm 0.298913
<   8 SNES Function norm 0.279868
<   9 SNES Function norm 0.26322
<  10 SNES Function norm 0.249106
<  11 SNES Function norm 0.236341
<  12 SNES Function norm 0.225242
<  13 SNES Function norm 0.214976
<  14 SNES Function norm 0.205853
<  15 SNES Function norm 0.168755
<  16 SNES Function norm 0.150005
<  17 SNES Function norm 0.146453
<  18 SNES Function norm 0.122221
<  19 SNES Function norm 0.109397
<  20 SNES Function norm 0.107737
<  21 SNES Function norm 0.106311
<  22 SNES Function norm 0.0907226
<  23 SNES Function norm 0.0813505
<  24 SNES Function norm 0.0796973
<  25 SNES Function norm 0.0782834
<  26 SNES Function norm 0.0770559
<  27 SNES Function norm 0.0758003
<  28 SNES Function norm 0.0746744
<  29 SNES Function norm 0.0740446
<  30 SNES Function norm 0.061927
<  31 SNES Function norm 0.0549197
<  32 SNES Function norm 0.054583
<  33 SNES Function norm 0.0519673
<  34 SNES Function norm 0.0498744
<  35 SNES Function norm 0.0491159
<  36 SNES Function norm 0.0482318
<  37 SNES Function norm 0.047538
<  38 SNES Function norm 0.0468002
<  39 SNES Function norm 0.0461691
<  40 SNES Function norm 0.0459809
<  41 SNES Function norm 0.0420109
<  42 SNES Function norm 0.0389469
<  43 SNES Function norm 0.0383224
<  44 SNES Function norm 0.0378171
<  45 SNES Function norm 0.0375595
<  46 SNES Function norm 0.0373267
<  47 SNES Function norm 0.0370906
<  48 SNES Function norm 0.0368703
<  49 SNES Function norm 0.0366439
<  50 SNES Function norm 0.0364308
>   1 SNES Function norm 1.73715
>   2 SNES Function norm 44.1655
>   3 SNES Function norm 2.72388e+10
> [0]PETSC ERROR: Vec entry at local location 8 is not-a-number or infinite at end of function: Parameter number 3!
> [0]PETSC ERROR: ./ex5 on a arch-gnu named Barrys-MacBook-Pro.local by barrysmith Mon Aug 13 21:12:21 2012
> [0]PETSC ERROR: SNESFASDownSmooth_Private() line 420 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
> [0]PETSC ERROR: SNESFASCycle_Additive() line 638 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
> [0]PETSC ERROR: SNESSolve_FAS() line 776 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
> [0]PETSC ERROR: SNESFASCycle_Additive() line 635 in /Users/barrysmith/Src/petsc-dev/src/snes/impls/fas/fas.c
Possible problem with with ex5_5_fas_additive, diffs above
