[petsc-dev] why does MatCreate_MPIDense still exist?
    Lisandro Dalcin
    dalcinl at gmail.com
    Mon Aug 13 11:49:40 CDT 2012
On 13 August 2012 13:47, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 13, 2012, at 11:44 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> On 13 August 2012 13:40, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>    Should I remove all the MPIDense stuff from PETSc now?   It is uses PLAPACK which is buggy and unsupported.
>> Do you mean to completely kill the subtype implementation?
>    Yes, people will use the new elemental interface for dense matrices.    Will that not work for your needs?  Could you live with a MPIDense that did not use PLAPACK? So had very limited functionality?
As long as we have some kind of dense implementation (mostly for
debugging purposes), I'm fine.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
