[petsc-dev] why does MatCreate_MPIDense still exist?
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Aug 13 11:47:19 CDT 2012
On Aug 13, 2012, at 11:44 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 13 August 2012 13:40, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>    Should I remove all the MPIDense stuff from PETSc now?   It is uses PLAPACK which is buggy and unsupported.
> Do you mean to completely kill the subtype implementation?
   Yes, people will use the new elemental interface for dense matrices.    Will that not work for your needs?  Could you live with a MPIDense that did not use PLAPACK? So had very limited functionality?
     Barry
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> 3000 Santa Fe, Argentina
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
