[petsc-dev] MetSetBlockSize issue
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Apr 24 22:14:12 CDT 2012
On Apr 24, 2012, at 8:14 PM, Mark F. Adams wrote:
> On Apr 24, 2012, at 5:01 PM, Barry Smith wrote:
>> On Apr 24, 2012, at 2:38 PM, Mark F. Adams wrote:
>>> On Apr 24, 2012, at 3:28 PM, Hong Zhang wrote:
>>>> Mark :
>>>> Shall C=PtAP inherit the block size of A?
>>>> Currently, MatPtAP() is only implemented with aij bs=1.
>>> No, as I said, algebraically it should inherit the column block size of P, but that is not available.
>> What is the column block size of P and how do you know what it is?
> I now attach it to the P matrix instead of adding it as a return parameter of the create P method.  So I keep track of it in the code.  Its size is the number of null space vectors.
  Ok if P knows its block size then the code that computes PtAP can set the block size of the resulting matrix as it creates it using the information in P. So is the issue on calling MatSetBlockSize() now resolved and everyone happy?
   Barry
> Mark
>>  Barry
>>> Perhaps PtAP should take a parameter for the block size ...
>>> Mark
>>>> Hong
>>>> On Apr 24, 2012, at 2:55 PM, Barry Smith wrote:
>>>>> On Apr 24, 2012, at 1:39 PM, Mark F. Adams wrote:
>>>>>> Now I'm getting this error with code like this:
>>>>>>   ierr = MatGetSubMatrix( Cmat, new_eq_indices, new_eq_indices, MAT_INITIAL_MATRIX, &mat );
>>>>>>   CHKERRQ(ierr);
>>>>>>   ierr = MatSetBlockSize( mat, cbs );      CHKERRQ(ierr);
>>>>>> and like this:
>>>>>> ierr = MatPtAP( Amat_fine, Pold, MAT_INITIAL_MATRIX, 2.0, &Cmat ); CHKERRQ(ierr);
>>>>>> ierr = MatSetBlockSize( Cmat, cbs );      CHKERRQ(ierr);
>>>>> Right you cannot do this. The matrix already exists so you cannot now set its size.
>>>>> Does Cmat have a block size of cbs
>>>>>  What about Amat?   By default these routines should create the new matrix with the correct blocksize.
>>>>>  The harder part is if the blocksize of mat would be different than Cmat?
>>>> It seems like MatGetSubMatrix should just inherit the block size but PtAP is harder.  The block size of the Cmat is the column block size of P.  But I can not set a column block size (!= row block size) so I don't set block size on P at all.  Here cbs is this column block size of P, or what it should be.
>>>> Mark
>>>>> Barry
>>>>>> Mark
>>>>>> On Apr 23, 2012, at 9:09 PM, Barry Smith wrote:
>>>>>>> Yes, look, for example how ex32 is handled at the bottom of the makefile.
>>>>>>> Thanks
>>>>>>> Barry
>>>>>>> On Apr 23, 2012, at 5:50 PM, Mark F. Adams wrote:
>>>>>>>> On Apr 23, 2012, at 5:59 PM, Barry Smith wrote:
>>>>>>>>> It was changed a while ago that MatSetBlockSize() couldn't be set after the matrix was full instantiated. I guess that example did not get fixed because it is not listed in the makefile to run in the makeall.
>>>>>>>> May I add it?
>>>>>>>>> I have fixed the example to call MatSetBlockSize() at a safe point.
>>>>>>>>> Barry
>>>>>>>>> On Apr 23, 2012, at 4:29 PM, Mark F. Adams wrote:
>>>>>>>>>> ex55.c in ksp is failing with:
>>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>>>>>>> [0]PETSC ERROR: Arguments are incompatible!
>>>>>>>>>> [0]PETSC ERROR: Cannot change block size 1 to 2!
>>>>>>>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>>>>>>>> on this line 57 of ex55.c:
>>>>>>>>>> ierr = MatSetBlockSize(Amat,2);      CHKERRQ(ierr);
>>>>>>>>>> Any idea what happened here?
>>>>>>>>>> Mark
