[petsc-dev] MetSetBlockSize issue
    Mark F. Adams
    mark.adams at columbia.edu
    Tue Apr 24 20:14:25 CDT 2012
On Apr 24, 2012, at 5:01 PM, Barry Smith wrote:
> On Apr 24, 2012, at 2:38 PM, Mark F. Adams wrote:
>> On Apr 24, 2012, at 3:28 PM, Hong Zhang wrote:
>>> Mark :
>>> Shall C=PtAP inherit the block size of A?
>>> Currently, MatPtAP() is only implemented with aij bs=1.
>> No, as I said, algebraically it should inherit the column block size of P, but that is not available.
>  What is the column block size of P and how do you know what it is?
I now attach it to the P matrix instead of adding it as a return parameter of the create P method.  So I keep track of it in the code.  Its size is the number of null space vectors.
>   Barry
>> Perhaps PtAP should take a parameter for the block size ...
>> Mark
>>> Hong
>>> On Apr 24, 2012, at 2:55 PM, Barry Smith wrote:
>>>> On Apr 24, 2012, at 1:39 PM, Mark F. Adams wrote:
>>>>> Now I'm getting this error with code like this:
>>>>>    ierr = MatGetSubMatrix( Cmat, new_eq_indices, new_eq_indices, MAT_INITIAL_MATRIX, &mat );
>>>>>    CHKERRQ(ierr);
>>>>>    ierr = MatSetBlockSize( mat, cbs );      CHKERRQ(ierr);
>>>>> and like this:
>>>>> ierr = MatPtAP( Amat_fine, Pold, MAT_INITIAL_MATRIX, 2.0, &Cmat ); CHKERRQ(ierr);
>>>>> ierr = MatSetBlockSize( Cmat, cbs );      CHKERRQ(ierr);
>>>>  Right you cannot do this. The matrix already exists so you cannot now set its size.
>>>>  Does Cmat have a block size of cbs
>>>>   What about Amat?   By default these routines should create the new matrix with the correct blocksize.
>>>>   The harder part is if the blocksize of mat would be different than Cmat?
>>> It seems like MatGetSubMatrix should just inherit the block size but PtAP is harder.  The block size of the Cmat is the column block size of P.  But I can not set a column block size (!= row block size) so I don't set block size on P at all.  Here cbs is this column block size of P, or what it should be.
>>> Mark
>>>>  Barry
>>>>> Mark
>>>>> On Apr 23, 2012, at 9:09 PM, Barry Smith wrote:
>>>>>> Yes, look, for example how ex32 is handled at the bottom of the makefile.
>>>>>> Thanks
>>>>>> Barry
>>>>>> On Apr 23, 2012, at 5:50 PM, Mark F. Adams wrote:
>>>>>>> On Apr 23, 2012, at 5:59 PM, Barry Smith wrote:
>>>>>>>> It was changed a while ago that MatSetBlockSize() couldn't be set after the matrix was full instantiated. I guess that example did not get fixed because it is not listed in the makefile to run in the makeall.
>>>>>>> May I add it?
>>>>>>>> I have fixed the example to call MatSetBlockSize() at a safe point.
>>>>>>>> Barry
>>>>>>>> On Apr 23, 2012, at 4:29 PM, Mark F. Adams wrote:
>>>>>>>>> ex55.c in ksp is failing with:
>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>>>>>> [0]PETSC ERROR: Arguments are incompatible!
>>>>>>>>> [0]PETSC ERROR: Cannot change block size 1 to 2!
>>>>>>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>>>>>>> on this line 57 of ex55.c:
>>>>>>>>> ierr = MatSetBlockSize(Amat,2);      CHKERRQ(ierr);
>>>>>>>>> Any idea what happened here?
>>>>>>>>> Mark
