[petsc-dev] 4.2 and PETSc
    Daniel Lowell
    redratio1 at gmail.com
    Mon Apr 23 16:32:02 CDT 2012
Sure, one sec.
On Mon, Apr 23, 2012 at 4:29 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Apr 23, 2012 at 5:27 PM, Daniel Lowell <redratio1 at gmail.com>wrote:
>> Hi all,
>> Has anyone run into any problems with NVCC 4.1 or .42 on PETSc with
>> arch=sm_20?
>> I have having real issues with it. I keep getting this:
> Can you send the whole make.log to petsc-maint?
>   Matt
>> #$ cicc  -arch compute_20 -m64 -ftz=0 -prec_div=1 -prec_sqrt=1 -fmad=1 -g
>> -O0 "/tmp/tmpxft_00000b8b_00000000-10_vecgpu"
>> "/tmp/tmpxft_00000b8b_00000000-7_vecgpu.cpp3.i"  -o
>> "/tmp/tmpxft_00000b8b_00000000-2_vecgpu.ptx"
>> <built-in>(2): error: "__STDC_HOSTED__" is predefined; attempted
>> redefinition ignored
>> <built-in>(8): error: "__WCHAR_TYPE__" is predefined; attempted
>> <built-in>(115): error: "__x86_64" is predefined; attempted redefinition
>> ignored
>> <built-in>(116): error: "__x86_64__" is predefined; attempted
>> <built-in>(126): error: "__linux__" is predefined; attempted redefinition
>> ignored
>> <built-in>(128): error: "__unix__" is predefined; attempted redefinition
>> ignored
>> 6 errors detected in the compilation of
>> "/tmp/tmpxft_00000b8b_00000000-7_vecgpu.cpp3.i".
>> # --error 0x1 --
>> 4.0 works fine, no issues.
>> 4.0 version uses the older nvopencc, in 4.1 and 4.2 they use something
>> called cicc, for target architecture sm_2x. Of course it does no mention
>> cicc in the updated nvcc documentation at all.
>> Tried 4.2 with GCC 4.3 and 4.4 without any difference in behavior.
>> PETSc configuration script:
>> MPI_DIR="--with-mpi-dir=$MPICH2_HOME"
>> LAD="--download-f-blas-lapack=yes"
>> CUD="--with-cuda-dir=/soft/cuda-4.2/cuda"
>> ./config/configure.py $MPI_DIR $LAD $CUD \
>> --with-debugging=1 \
>> --with-cudac="nvcc -m64 -g -G" \
>> --with-precision=double \
>> --with-clanguage=c \
>> --with-cuda-arch=sm_20
>> Daniel Lowell
> experiments lead.
> -- Norbert Wiener
Daniel Lowell
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120423/c0618ea7/attachment.html>
