[petsc-dev] 4.2 and PETSc
    Matthew Knepley
    knepley at gmail.com
    Mon Apr 23 16:29:41 CDT 2012
On Mon, Apr 23, 2012 at 5:27 PM, Daniel Lowell <redratio1 at gmail.com> wrote:
> Hi all,
> Has anyone run into any problems with NVCC 4.1 or .42 on PETSc with
> arch=sm_20?
> I have having real issues with it. I keep getting this:
Can you send the whole make.log to petsc-maint?
  Matt
> #$ cicc  -arch compute_20 -m64 -ftz=0 -prec_div=1 -prec_sqrt=1 -fmad=1 -g
> -O0 "/tmp/tmpxft_00000b8b_00000000-10_vecgpu"
> "/tmp/tmpxft_00000b8b_00000000-7_vecgpu.cpp3.i"  -o
> "/tmp/tmpxft_00000b8b_00000000-2_vecgpu.ptx"
> <built-in>(2): error: "__STDC_HOSTED__" is predefined; attempted
> redefinition ignored
> <built-in>(8): error: "__WCHAR_TYPE__" is predefined; attempted
> <built-in>(115): error: "__x86_64" is predefined; attempted redefinition
> ignored
> <built-in>(116): error: "__x86_64__" is predefined; attempted redefinition
> ignored
> <built-in>(126): error: "__linux__" is predefined; attempted redefinition
> ignored
> <built-in>(128): error: "__unix__" is predefined; attempted redefinition
> ignored
> 6 errors detected in the compilation of
> "/tmp/tmpxft_00000b8b_00000000-7_vecgpu.cpp3.i".
> # --error 0x1 --
> 4.0 works fine, no issues.
> 4.0 version uses the older nvopencc, in 4.1 and 4.2 they use something
> called cicc, for target architecture sm_2x. Of course it does no mention
> cicc in the updated nvcc documentation at all.
> Tried 4.2 with GCC 4.3 and 4.4 without any difference in behavior.
> PETSc configuration script:
> MPI_DIR="--with-mpi-dir=$MPICH2_HOME"
> LAD="--download-f-blas-lapack=yes"
> CUD="--with-cuda-dir=/soft/cuda-4.2/cuda"
> ./config/configure.py $MPI_DIR $LAD $CUD \
> --with-debugging=1 \
> --with-cudac="nvcc -m64 -g -G" \
> --with-precision=double \
> --with-clanguage=c \
> --with-cuda-arch=sm_20
> Daniel Lowell
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120423/27cd3d91/attachment.html>
