[petsc-dev] Cross compile with .c and .cu files
Satish Balay
balay at mcs.anl.gov
Mon Apr 23 16:26:43 CDT 2012
'make libfast' can't handle different file types [but 'make lib' can].
For libfast to work - you can split up the sources into multiple dirs.
i.e
src/mat/impls/dia/seq/dia.c
src/mat/impls/dia/seq/seqcusp/diakerns.cu
Satish
On Mon, 23 Apr 2012, Daniel Lowell wrote:
> Hi all,
> I'm building a matrix type with two separate files dai.c and diakerns.cu.
> If I "make all" in the PETSc root dir, it will be unable to find the object
> file from the .cu file; i.e., I get this:
> /usr/bin/ar: diakerns.o: No such file or directory
> However if I merely do a "make lib" inside the matrix type directory I have
> no problem. This has happened to other types I've create, I end up just
> shoving everything into one large .cu file to quickly deal with it.
> Here what the folder level makefile looks like:
> SOURCECU = diakerns.cu
> SOURCEC = dia.c
> SOURCEF =
> SOURCEH = dia.h
> OBJSC = dia.o diakerns.o
> OBJSF =
> LIBBASE = libpetscmat
> DIRS =
> MANSEC = Mat
> LOCDIR = src/mat/impls/dia/seq/
> This is what my configuration script for petsc root looks like:
> MPI_DIR="--with-mpi-dir=$MPICH2_HOME"
> LAD="--download-f-blas-lapack=yes"
> CUD="--with-cuda-dir=/soft/cuda-4.2/cuda"
> ./config/configure.py $MPI_DIR $LAD $CUD \
> --with-debugging=1 \
> --with-cudac="nvcc -m64 -g -G -v" \
> --with-precision=double \
> --with-clanguage=c \
> --with-cuda-arch=sm_20 \
