[petsc-dev] MatAXPY with DIFFERENT_NONZERO_PATTERN
    Jed Brown
    jedbrown at mcs.anl.gov
    Sun Apr 22 20:23:58 CDT 2012
Thanks for the test case. Fixed here:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/7ac7040f19d7
On Sun, Apr 22, 2012 at 08:11, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
> Matt,
> Here are matrices (double complex, 3 MB each):
> http://dl.dropbox.com/u/60982984/X.dat
> http://dl.dropbox.com/u/60982984/Y.dat
> Code:
> static char help[] = "";
> int main(int argc,char **args)
>   Mat            A,B;
>   PetscErrorCode ierr;
>   PetscViewer    viewer;
>   PetscScalar    cone;
>   PetscInitialize(&argc,&args,(char *)0,help);
>   ierr =
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Y.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>   ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>   ierr = MatSetFromOptions(A);CHKERRQ(ierr);
>   ierr = MatLoad(A,viewer);CHKERRQ(ierr);
>   ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>   ierr =
> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"X.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>   ierr = MatCreate(PETSC_COMM_WORLD,&B);CHKERRQ(ierr);
>   ierr = MatSetFromOptions(B);CHKERRQ(ierr);
>   ierr = MatLoad(B,viewer);CHKERRQ(ierr);
>   cone = 1.0;
>   ierr = MatAYPX(A,cone,B,DIFFERENT_NONZERO_PATTERN);
>   ierr = PetscFinalize();
>   return 0;
> It works fine if you run it with:
> mpirun -n 10 solveTest -mat_type aij
> and crashes if n > 10
> Thanks.
> On 22.04.2012 14:51, Matthew Knepley wrote:
> On Sun, Apr 22, 2012 at 8:41 AM, Alexander Grayver <
> agrayver at gfz-potsdam.de> wrote:
>>  Sorry, I don't quite get. Is this something I can avoid by doing
>> preallocation properly or petsc issue that will be fixed?
>  This looks like a PETSc bug to me, but it would be nice to get input
> that triggers it.
>    Thanks,
>       Matt
>>   On 20.04.2012 14:23, Jed Brown wrote:
>> On Fri, Apr 20, 2012 at 05:18, Matthew Knepley <knepley at gmail.com> wrote:
>>> Did someone intend to fix this, and then
>>> stop? MatAXPY_BasicWithPreallocation() is the same as MatAXPY_Basic().
>>  Look how it's called. I don't know what's going on here.
>>      ierr =
>> MatAXPYGetPreallocation_SeqAIJ(yy->A,xx->A,nnz_d);CHKERRQ(ierr);
>>     ierr =
>> MatAXPYGetPreallocation_SeqAIJ(yy->B,xx->B,nnz_o);CHKERRQ(ierr);
>>     ierr = MatMPIAIJSetPreallocation(B,0,nnz_d,0,nnz_o);CHKERRQ(ierr);
>>     ierr = MatAXPY_BasicWithPreallocation(B,Y,a,X,str);CHKERRQ(ierr);
>> Regards,
>> Alexander
> experiments lead.
> -- Norbert Wiener
> Regards,
> Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120422/7c33bbaa/attachment.html>
