[petsc-dev] MatAXPY with DIFFERENT_NONZERO_PATTERN
    Alexander Grayver
    agrayver at gfz-potsdam.de
    Sun Apr 22 08:11:33 CDT 2012
Matt,
Here are matrices (double complex, 3 MB each):
http://dl.dropbox.com/u/60982984/X.dat
http://dl.dropbox.com/u/60982984/Y.dat
Code:
static char help[] = "";
int main(int argc,char **args)
   Mat            A,B;
   PetscErrorCode ierr;
   PetscViewer    viewer;
   PetscScalar    cone;
   PetscInitialize(&argc,&args,(char *)0,help);
   ierr =
PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Y.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
   ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
   ierr = MatSetFromOptions(A);CHKERRQ(ierr);
   ierr = MatLoad(A,viewer);CHKERRQ(ierr);
   ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
   ierr =
PetscViewerBinaryOpen(PETSC_COMM_WORLD,"X.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
   ierr = MatCreate(PETSC_COMM_WORLD,&B);CHKERRQ(ierr);
   ierr = MatSetFromOptions(B);CHKERRQ(ierr);
   ierr = MatLoad(B,viewer);CHKERRQ(ierr);
   cone = 1.0;
   ierr = MatAYPX(A,cone,B,DIFFERENT_NONZERO_PATTERN);
   ierr = PetscFinalize();
   return 0;
It works fine if you run it with:
mpirun -n 10 solveTest -mat_type aij
and crashes if n > 10
Thanks.
On 22.04.2012 14:51, Matthew Knepley wrote:
> On Sun, Apr 22, 2012 at 8:41 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     Sorry, I don't quite get. Is this something I can avoid by doing
>     preallocation properly or petsc issue that will be fixed?
> This looks like a PETSc bug to me, but it would be nice to get input
> that triggers it.
>   Thanks,
>      Matt
>     On 20.04.2012 14:23, Jed Brown wrote:
>>     On Fri, Apr 20, 2012 at 05:18, Matthew Knepley <knepley at gmail.com
>>     <mailto:knepley at gmail.com>> wrote:
>>         Did someone intend to fix this, and then
>>         stop? MatAXPY_BasicWithPreallocation() is the same
>>         as MatAXPY_Basic().
>>     Look how it's called. I don't know what's going on here.
>>         ierr =
>>     MatAXPYGetPreallocation_SeqAIJ(yy->A,xx->A,nnz_d);CHKERRQ(ierr);
>>         ierr =
>>     MatAXPYGetPreallocation_SeqAIJ(yy->B,xx->B,nnz_o);CHKERRQ(ierr);
>>         ierr =
>>     MatMPIAIJSetPreallocation(B,0,nnz_d,0,nnz_o);CHKERRQ(ierr);
>>         ierr = MatAXPY_BasicWithPreallocation(B,Y,a,X,str);CHKERRQ(ierr);
>     Regards,
>     Alexander
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120422/f09cfae0/attachment.html>
