[petsc-dev] Recommended Petsc Build Procedure
Dave Nystrom
Dave.Nystrom at tachyonlogic.com
Sun Apr 22 09:42:34 CDT 2012
At the end of configure.log, there are two possible ways to build petsc-dev
that are specified. Which is the recommended way to build - using make or
using python? I have been using make.
Also, one is labeled as legacy and one is labeled as experimental. That
gives the impression of having a choice between an old, archaic method or a
new, experimental approach. Should one just be labeled as production?
Dave
