[petsc-dev] MatAXPY with DIFFERENT_NONZERO_PATTERN
Alexander Grayver
agrayver at gfz-potsdam.de
Sun Apr 22 07:41:42 CDT 2012
Sorry, I don't quite get. Is this something I can avoid by doing
preallocation properly or petsc issue that will be fixed?
On 20.04.2012 14:23, Jed Brown wrote:
> On Fri, Apr 20, 2012 at 05:18, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
> Did someone intend to fix this, and then
> stop? MatAXPY_BasicWithPreallocation() is the same as MatAXPY_Basic().
> Look how it's called. I don't know what's going on here.
> ierr =
> MatAXPYGetPreallocation_SeqAIJ(yy->A,xx->A,nnz_d);CHKERRQ(ierr);
> ierr =
> MatAXPYGetPreallocation_SeqAIJ(yy->B,xx->B,nnz_o);CHKERRQ(ierr);
> ierr = MatMPIAIJSetPreallocation(B,0,nnz_d,0,nnz_o);CHKERRQ(ierr);
> ierr = MatAXPY_BasicWithPreallocation(B,Y,a,X,str);CHKERRQ(ierr);
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120422/5f02f1d7/attachment.html>
