[petsc-dev] MatAXPY with DIFFERENT_NONZERO_PATTERN
    Alexander Grayver
    agrayver at gfz-potsdam.de
    Fri Apr 20 05:07:28 CDT 2012
Hello,
Calling MatAYPX with MatStructure == DIFFERENT_NONZERO_PATTERN produces
following errors:
[30]PETSC ERROR: --------------------- Error Message
[30]PETSC ERROR: Argument out of range!
[30]PETSC ERROR: New nonzero at (0,8486) caused a malloc!
[30]PETSC ERROR:
[30]PETSC ERROR: Petsc Development HG revision:
7c3c3f8c0d65b793aea33c138419de755b591ca7  HG Date: Thu Feb 09 14:42:30
2012 -0600
[30]PETSC ERROR: See docs/changes/index.html for recent updates.
[30]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[30]PETSC ERROR: See docs/index.html for manual pages.
[30]PETSC ERROR:
[30]PETSC ERROR: /home/prog on a openmpi-i named node229 by agrayver Fri
Apr 20 11:33:55 2012
[30]PETSC ERROR: Libraries linked from
/home/lib/petsc-dev/openmpi-intel-complex-debug-f/lib
[30]PETSC ERROR: Configure run at Fri Feb 10 09:28:34 2012
[30]PETSC ERROR: Configure options
--with-petsc-arch=openmpi-intel-complex-debug-f
--with-fortran-interfaces=1
--with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a
--with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a
--with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex
--with-blas-lapack-lib="[/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_intel_lp64.a,/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_intel_thread.a,/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_core.a,/opt/intel/Compiler/11.1/072/lib/intel64/libiomp5.a]"
--with-precision=double --with-x=0
[30]PETSC ERROR:
[30]PETSC ERROR: MatSetValues_MPIAIJ() line 538 in
/home/lib/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c
[30]PETSC ERROR: MatSetValues() line 1129 in
/home/lib/petsc-dev/src/mat/interface/matrix.c
[30]PETSC ERROR: MatAXPY_BasicWithPreallocation() line 108 in
/home/lib/petsc-dev/src/mat/utils/axpy.c
[30]PETSC ERROR: MatAXPY_MPIAIJ() line 2235 in
[30]PETSC ERROR: MatAXPY() line 39 in
[30]PETSC ERROR: MatAYPX() line 272 in
I guess it has something to do with recent changes in mataij
implementation, doesn't it?
Alexander
