[petsc-dev] A few remaining issues with Mat block sizes
Lisandro Dalcin
dalcinl at gmail.com
Tue Apr 10 04:36:59 CDT 2012
Barry, could you review the attached patch? Basically, many Mat
preallocation routines should not set the block size to 1, and instead
honor what the user could have set calling MatSetBlockSize(). Please
note that in this patch I'm not addressing all instances of this issue
in the codebase, I've just worked on some of the matrix types
(seq/mpidense, seq/mpiaij, shell) that I know for sure the fix seems
to make sense.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120410/b419b710/attachment.obj>
