[petsc-dev] petsc4py import error on OS X: PETSc.so,	2): Symbol not found: _KSP_CLASSID
    Aron Ahmadia
    aron at ahmadia.net
    Sun Apr  8 08:18:56 CDT 2012
If you are seeing this, it's because you installed petsc4py against a
static PETSc.  Rebuild the PETSc with shared libraries enabled and this
error will go away.
A
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120408/c291e510/attachment.html>
