[petsc-dev] Weird interaction between VecDuplicate and VecSetBlockSize
Barry Smith
bsmith at mcs.anl.gov
Wed Apr 4 21:17:14 CDT 2012
On Apr 4, 2012, at 9:16 PM, Jed Brown wrote:
> On Sat, Mar 31, 2012 at 20:03, Barry Smith <bsmith at mcs.anl.gov> wrote:
> For non-blocked matrices you can call MatSetBlockSize() anytime (as with vectors changing the blocksize later will also change the block size of any other vectors/matrices that share the layout) , for blocked matrices you CANNOT ever call MatSetBlockSize() and must set it with the appropriate preallocation routine.
> Not quite. You can set the block size for BAIJ, but it just checks that it matches the block size used for preallocation and errors if not.
And this makes a difference how?
