[petsc-dev] Weird interaction between VecDuplicate and VecSetBlockSize
Wed Apr 4 21:16:03 CDT 2012
On Sat, Mar 31, 2012 at 20:03, Barry Smith <bsmith at mcs.anl.gov> wrote:
> For non-blocked matrices you can call MatSetBlockSize() anytime (as with
> vectors changing the blocksize later will also change the block size of any
> other vectors/matrices that share the layout) , for blocked matrices you
> CANNOT ever call MatSetBlockSize() and must set it with the appropriate
> preallocation routine.
Not quite. You can set the block size for BAIJ, but it just checks that it
matches the block size used for preallocation and errors if not.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120404/34958473/attachment.html>
