[petsc-dev] sacusp preconditioner - limited to seqaijcusp matrices?
Barry Smith
bsmith at mcs.anl.gov
Tue Sep 20 11:58:43 CDT 2011
On Sep 20, 2011, at 11:54 AM, Brad Aagaard wrote:
> I tried running a PyLith simulation using the sacusp preconditioner rather than ml. If I have the mat_type set to mpiaijcusp, I get an error message that sacusp preconditioner only works with CUSP matrices. I checked sacusp.c and the code checks to make sure the mat_type is seqaijcusp.
Since the sacusp preconditioner is no MPI parallel it cannot deal with MPI matrices. ML is a truly (MPI) parallel multi-level preconditioner so it is not really interchangable with sacusp.
You can use block Jacobi preconditioning -pc_type bjacobi -sub_pc_type sacusp with sacusp on each block.
Barry
> Is sacusp limited to seqaijcusp or is this a bug and sacusp.c should allow mpiaijcusp matrices as well?
> Note: sacusp allowed a vec_type of mpicusp.
> Thanks,
> Brad
