[petsc-dev] parmetis broken (with 64 bit indices)?
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep  7 17:34:26 CDT 2011
On Sep 7, 2011, at 5:04 PM, Sean Farley wrote:
> Any estimate of when Parmetis will work with 64 bit indices?
> Now that my poster is done and petsc-3.2 is in its own repo, I'll continue on this. There was an issue with some dependent packages of parmetis (umfpack) which will have to be patched.
 Hmm, why? I believe the decision was that those dependent packages where told to fix themselves to use the latest ParMetis and until then they are not usuable from PETSc. Are we going to fix SuperLU_Dist, UMFPACK, MUMPS, etc etc. all ourselves to work with the latest Parmetis. That is a downstream?/upstream? problem not ours.
  Barry
> Sean
