[petsc-dev] petsc-dev build broken
    Mark F. Adams
    mark.adams at columbia.edu
    Tue Sep  6 13:50:42 CDT 2011
sorry my fault, fixing now.
mark
On Sep 6, 2011, at 2:38 PM, Satish Balay wrote:
> The makefile has:
> #requirespackage  'PETSC_HAVE_TRIANGLE'
> So unless --download-triangle=1 was used - this code shouldn't get compiled.
> And if triangle was indeed used - triangle.h should be found. Perhaps
> the error is somewhere else [perhaps in configure?]
> satish
> On Tue, 6 Sep 2011, Lisandro Dalcin wrote:
>> libfast in: /home/devel/petsc/dev/src/ksp/pc/impls/gamg
>> createProlongation.c:8:22: error: triangle.h: No such file or directory
>> createProlongation.c: In function ‘triangulateAndFormProl’:
>> createProlongation.c:794: error: storage size of ‘in’ isn’t known
>> createProlongation.c:794: error: storage size of ‘mid’ isn’t known
>> createProlongation.c:820: warning: left-hand operand of comma
>> expression has no effect
>> createProlongation.c:1063: warning: left-hand operand of comma
>> createProlongation.c:794: warning: unused variable ‘mid’
>> createProlongation.c:794: warning: unused variable ‘in’
>> /usr/bin/ar: createProlongation.o: No such file or directory
