[petsc-dev] petsc-dev build broken
    Satish Balay
    balay at mcs.anl.gov
    Tue Sep  6 13:38:42 CDT 2011
The makefile has:
#requirespackage  'PETSC_HAVE_TRIANGLE'
So unless --download-triangle=1 was used - this code shouldn't get compiled.
And if triangle was indeed used - triangle.h should be found. Perhaps
the error is somewhere else [perhaps in configure?]
satish
On Tue, 6 Sep 2011, Lisandro Dalcin wrote:
> libfast in: /home/devel/petsc/dev/src/ksp/pc/impls/gamg
> createProlongation.c:8:22: error: triangle.h: No such file or directory
> createProlongation.c: In function ‘triangulateAndFormProl’:
> createProlongation.c:794: error: storage size of ‘in’ isn’t known
> createProlongation.c:794: error: storage size of ‘mid’ isn’t known
> createProlongation.c:820: warning: left-hand operand of comma
> expression has no effect
> createProlongation.c:1063: warning: left-hand operand of comma
> createProlongation.c:794: warning: unused variable ‘mid’
> createProlongation.c:794: warning: unused variable ‘in’
> /usr/bin/ar: createProlongation.o: No such file or directory
