[petsc-dev] [petsc-users] PETSc 3.2 release candidate
    Satish Balay
    balay at mcs.anl.gov
    Fri Sep  2 21:01:27 CDT 2011
Also one can use the following tarball. It will correspond to
petsc-3.2 sources for the next few days. And i've set it up to be
updated every 3 hours [from the sources in mercurial].
http://ftp.mcs.anl.gov/pub/petsc/petsc-dev.tar.gz
Satish
On Fri, 2 Sep 2011, Barry Smith wrote:
>    You can find the PETSc 3.2 release candidate via Mecurial at:
> > ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.2                        or    http://petsc.cs.iit.edu/petsc/releases/petsc-3.2
> > ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/BuildSystem-3.2           or    http://petsc.cs.iit.edu/petsc/releases/BuildSystem-3.2
>    If you find any problems please let us know.  We'll be making the tarball in a couple of days.
>    Thanks
>     Barry
>    If you fix anything, please make the fix in petsc-3.2 not petsc-dev
