[petsc-dev] PETSc 3.2 release candidate
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Sep  2 20:18:26 CDT 2011
   You can find the PETSc 3.2 release candidate via Mecurial at:
> ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.2                        or    http://petsc.cs.iit.edu/petsc/releases/petsc-3.2
> ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/BuildSystem-3.2           or    http://petsc.cs.iit.edu/petsc/releases/BuildSystem-3.2
   If you find any problems please let us know.  We'll be making the tarball in a couple of days.
   Thanks
    Barry
   If you fix anything, please make the fix in petsc-3.2 not petsc-dev
