[petsc-dev] Problem mixing sieve and TS
    Paul Sicsic
    paul.sicsic at polytechnique.edu
    Thu Oct 27 00:40:46 CDT 2011
I have attached the output of valgrind for a run with no options and for a
run with the options you have recommended earlier.
2011/10/27 Jed Brown <jedbrown at mcs.anl.gov>
> On Wed, Oct 26, 2011 at 23:30, Paul Sicsic <paul.sicsic at polytechnique.edu>wrote:
>> Yes ex22f runs correctly.
>> We have tested this on different architectures (ubuntu, darwin) and
>> compilers (intel, gcc).
> Did Valgrind turn anything up?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111027/d8619684/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111027/d8619684/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111027/d8619684/attachment-0001.obj>
