[petsc-dev] TSSolve() shouldn't return a time
Matthew Knepley
knepley at gmail.com
Sun Oct 23 15:46:31 CDT 2011
On Sun, Oct 23, 2011 at 8:31 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Oct 23, 2011, at 3:26 PM, Jed Brown wrote:
> > On Sun, Oct 23, 2011 at 15:18, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > I wasn't thinking of anything so complicated. Just having a separate
> routine TSGetCurrentTime() or something to tell you the time after you
> called TSSolve().
> > But it's not the current time in the sense that it doesn't correspond to
> TSGetSolution or any Vec held by TS and it is not used if you call TSStep()
> or TSSolve(). It's a purely diagnostic point in time with no other
> significance. I can change the TSSolve() interface if we think of a good
> name for this thing.
> Wow, that is confusing then :-) So almost every thing in the manual
> page is wrong? It may include "partial time-steps"? And x is some weird
> shit that should not be passed back into TSSolve()? What the ? Is ftime the
> "interpolated to" time?
This seems like a confusion between the continuum level and the discrete
level.
Matt
> Barry
> TSSolve - Steps the requested number of timesteps.
> Collective on TS
> Input Parameter:
> + ts - the TS context obtained from TSCreate()
> - x - the solution vector
> Output Parameter:
> . ftime - time of the state vector x upon completion
> Level: beginner
> Notes:
> The final time returned by this function may be different from the time
> of the internally
> held state accessible by TSGetSolution() and TSGetTime() because the
> method may have
> stepped over the final time.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111023/94bbe475/attachment.html>
