[petsc-dev] HDF5 has pissed me off one too many times
Sean Farley
sean at mcs.anl.gov
Thu Oct 20 14:01:42 CDT 2011
> The build fails. Turn off the patch and use --download-hdf5 with GNU
> Fortran (GCC) 4.6.0 20101106 (experimental).
It seems this is because you are using a buggy gfortran compiler. I have GCC
4.6.1 and the configure goes through fine. Just to make sure, I uninstalled
any hdf5 I had installed in other places.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111020/997ad838/attachment.html>
Type: application/x-bzip2
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111020/997ad838/attachment.bz2>
