[petsc-dev] HDF5 has pissed me off one too many times
Matthew Knepley
knepley at gmail.com
Thu Oct 20 13:28:42 CDT 2011
On Thu, Oct 20, 2011 at 6:25 PM, Sean Farley <sean at mcs.anl.gov> wrote:
> I put in a patch for HDF5 since it broke when installing with gfortran on
>> the Mac.
> What was the error that you were patching? I have HDF5 installed on my Mac
> but haven't run into anything (granted, I'm not an advanced user of HDF5).
> Could you point to a breaking case? Also, are you using the new cmake that
> hdf5 has put out? That fixes building cxx with fortran (but still no mpi)
> into shared libraries.
> Also, I notice that hdf5.py still uses 1.8.6 and not the newest 1.8.7. Post
> the breaking case and I'll try to reproduce.
The build fails. Turn off the patch and use --download-hdf5 with GNU Fortran
(GCC) 4.6.0 20101106 (experimental). The
build of fortran/test/tH5Sselect.f90 fails. It is not even run, but HDF5
cleverly builds its tests anyway. I just comment out
the offending lines. I looked at the code, but could not identify the F90
problem.
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111020/cd0dfcb8/attachment.html>
