[petsc-dev] VecNestSetSubVec for VecNest.
Jed Brown
jedbrown at mcs.anl.gov
Mon Oct 17 21:00:30 CDT 2011
On Mon, Oct 17, 2011 at 20:55, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Actually, that is quite consistent in philosophy to the merge
> operation I'm trying to perform. SEQ->MPI might still be an invalid
> operation for Vec though. Perhaps with a PETSC_DECIDE for local, it
> still could be relevant ? You can definitely specialize this for
> MPI->SEQ and Nest Vectors with a new VecReuse enum with relevant
> names.
I would not try to simultaneously change the distribution of the Vec. That's
what VecScatter is for. VecConvert() would keep the same distribution and
give you back a semantically identical vector of a different type.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111017/08e7ba19/attachment.html>
