[petsc-dev] Moving from BG/L to BG/P
Thu Oct 13 23:11:55 CDT 2011
On Thu, Oct 13, 2011 at 23:01, <Kevin.Buckley at ecs.vuw.ac.nz> wrote:
> Hi there,
> Some time ago I built a PETSc (3.0.0-p9) on the BG/P down at NZ's
> Univ of Canterbury, for a researcher here at VUW who wanted to
> run the PISM ice-sheet modelling code on top of it, and in the
> process discovered that the version installed by the sys admins
> at the facility was buggy, so the researcher carried on compiling
> later PISMs against my 3.0.0-p9.
> UoC are in the process of upgrading to a BG/P and the researcher
> has asked me to see if I can coddle things together, is keen to
> run with what he had before and is under "time pressure" to get
> the remaining results needed for a paper, so is hoping I can
> install something ahead of the facility's sys admins install
> a system wide version.
> Notwithstanding the obvious upgrade in release of PETSc from our
> 3.0 series to the current 3.2, I notice that the petsc-bgl-tools
> wrapper package only (not surprisingly I guess, given the bgl bit)
> provided for IBM 7.0 and 8.0 compiler suites, so, have you guys
> tried out PETSc on a BG/P yet?
BG/P has been out for a while, so of course people have been running PETSc
on it for years. You can look at
config/examples/arch-bgp-ibm-opt.py
in the source tree. Here is a configuration that we used for some benchmarks
on Shaheen last year:
Configure options: --with-x=0 --with-is-color-value-type=short
--with-debugging=1 --with-fortran-kernels=1
--with-mpi-dir=/bgsys/drivers/ppcfloor/comm --with-batch=1
--known-mpi-shared-libraries=1 --known-memcmp-ok --known-sizeof-char=1
--known-sizeof-void-p=4 --known-sizeof-short=2 --known-sizeof-int=4
--known-sizeof-long=4 --known-sizeof-size_t=4 --known-sizeof-long-long=8
--known-sizeof-float=4 --known-sizeof-double=8 --known-bits-per-byte=8
--known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4
--known-mpi-long-double=1 --known-level1-dcache-assoc=0
--known-level1-dcache-linesize=32 --known-level1-dcache-size=32768
--download-hypre=1 --with-shared=0
--prefix=/opt/share/ksl/petsc/dev-dec9-hypre/ppc450d-bgp_xlc_hypre_fast
--with-clanguage=c --COPTFLAGS="     -O3 -qhot" --CXXOPTFLAGS="     -O3
-qhot" --FOPTFLAGS="     -O3 -qhot" --LIBS="
-L/bgsys/ibm_essl/sles10/prod/opt/ibmmath/lib -L/opt/ibmcmp/xlsmp/bg/1.7/lib
-L/opt/ibmcmp/xlmass/bg/4.4/bglib -L/opt/ibmcmp/xlf/bg/11.1/bglib
-L/opt/ibmcmp/xlmass/bg/4.4/bglib -L/opt/ibmcmp/xlf/bg/11.1/bglib   -lesslbg
 -lxlf90_r -lxlopt -lxlsmp -lxl -lxlfmath  -lesslbg  -lxlf90_r -lxlopt
-lxlsmp -lxl -lxlfmath -O3"
--CC=/bgsys/drivers/ppcfloor/comm/xl/bin/mpixlc_r
--CXX=/bgsys/drivers/ppcfloor/comm/xl/bin/mpixlcxx_r
--FC=/bgsys/drivers/ppcfloor/comm/xl/bin/mpixlf90_r --with-debugging=0
PETSC_ARCH=bgp-xlc-hypre-fast
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111013/c2852e5c/attachment.html>
