[petsc-dev] VecNestSetSubVec for VecNest.
Jed Brown
jedbrown at mcs.anl.gov
Thu Oct 13 08:15:08 CDT 2011
On Thu, Oct 13, 2011 at 00:55, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Attached is a test file with a routine VecNestSetSubVec to modify a
> block of a Nest vector after initial creation. This functionality does
> not exist as of now and this is my first crack at it. The test_vec_ops
> also has several variations of tests and all of them pass currently.
> The function VecSize_Nest_Recursive_duplicate, as the name suggests is
> a duplicate of "VecSize_Nest_Recursive" private routine in vecnest.c
> If you find something wrong, do let me know. Feel free to
> modify/optimize the routine as necessary as I feel it could use some
> level of recursion but I can't see it as of now. If the functionality
> is acceptable, perhaps the routine could be added to VecNest
> implementation.
Thanks. Would you be willing to put this routine into vecnest.c with dynamic
dispatch and a manual page (search for VecNestSetSubVec() and follow the
pattern)? You can put your test code in src/vec/vec/examples/tests/ with
output so that it gets run in the nightlies. Please follow the indenting and
code formatting guidelines, commit the patch, and send with hg bundle or hg
export.
Let me know if you don't have time or don't think you will ever contribute
to PETSc. But if you think you'll have other patches (ISNest ;-)), this
would be a good one to familiarize yourself with the process.
Barry, note that this implementation allows resizing by setting nested
blocks of a different size.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111013/13ad8397/attachment.html>
