[petsc-dev] shared libraries auto-rebuild
Thu Oct 13 07:54:47 CDT 2011
what do you have for:
ls -lt /system/software/hal/lib/PETSc/petsc-3.2-p3/icc-2011/lib
You can remove the target 'chkopts' from your makefile - and then it
shouldn't attempt this check/rebuild.
Satish
On Thu, 13 Oct 2011, Richard Katz wrote:
> Hi all,
> Just tried to compile my code on an Oxford cluster and got this error message:
> Shared libs in /system/software/hal/lib/PETSc/petsc-3.2-p3/icc-2011/lib are out of date, attempting to rebuild.
> *********************** ERROR ************************
> Unable to rebuild shared libraries; you do not have write permission.
> Libraries were built by user mihai; please contact him/her to have them rebuilt.
> This version of PETSc was freshly downloaded and installed, so I don't think that the libraries are actually out of date.
> What do you mean by "out of date"?  How do you check?  Is it possible to turn this feature off?
> Thanks,
> Rich
